Replaced Voodoo Engine
unknown internal failure, oil consumption, blown block, damaged valve train etc.
  • Total voters
    91
Lorne34
Project Hidalgo
Wisconsin
Lorne
2019 GT350
Because it's proof that there's a problem with the FPC 5.2. They're hoping to ride out the warranty period for as many FPC engines that they can.
your avatar is stressing me out.....:facepalm::frown:
GT350-H6088
Mustang with a Mouth
Independent Hill, VA
Scott
2017 Shelby GT350 (H6088) RR Black stripes/white p
just curious to the folks seeing oil loss: is the car smoking upon startup or during run? do you notice? oil doesn't just vanish; its either leaks out or is burnt. The latter will be noticeable if its burning that much...
Lots of soot on exhaust pipes tips. No Leaks, No smoke on startup. someone noticed when I was at the Track under heavy acceleration there was a puff of smoke
but that was it. My 2017 GT350 used 1 quart ever 120 miles.
sumfoo1
N/a
Bill
2018 Gt350, 57-tbird, 61 Galaxie, 2014 Wrangler unlimited rubicon, and a 1999 F150
I've read something about the gt350 changing blocks to the new gt500 block when the gt500 production begins.
Does anyone know if this is true?
Is this why the 2019s are taking so long to become availible?
Is it going to be all 2019s or should we wait till fall or something ?
GT350-H6088
Scott
Alain
Northern NJ
Alain
2016 Challenger Hellcat / 2019 350R #413
Yes, it is true. The block in the 350 is going to be replaced by the block from the 500.
Since the 500 won’t go into production until next year it stands to reason that the change in the block for the 350 won’t happen till the 2020 model year.
4score
2017 Shelby GT350
The engine in my 2017 GT350 is currently being replaced under warranty by Ford due to excess oil consumption, ~4 quarts over 1000 miles. The dealership has not shared with me any of the images or likely reasons for the issue.
Edward
ATX
Ford Lightning
Just a random datapoint...
Both GT350’s in Carvana have Carfax’s that show engine replacement/buyback due to oil consumption.
Tomster
Beware of idiots
Tom
I sure do wish I could buy one of those "excessive" oil consumption engines. I'd bet a rebuild of the valve train assembly would take care of that. Swap out the OPG to billet and a few minor refreshes and BAM!, you got yourself a track engine.
The core on these engines is only a few thousand bucks. Anyone undergoing engine replacement ask about buying the core. I will buy it from you.
DCShelby
DC
Robert
2020 Shadow Black GT350, Tech pack, Carbon Dash, Gurney Flap, leather seats
Pretty sure Ford is not letting people buy it back.
johnny1
Had new a 16 GT350 and 17 GT350
Most I read also Ford won't let you buy it they don't want you to know what the underlying issue really is.
rick81721
Venice, FL and Flemington, NJ
Rick
2017 GT350 LB H6153
Dang I should've asked when they swapped mine
Tomster
Beware of idiots
Tom
That is the norm, yes. All it takes is one service manager to say "sure, you can have it for the core fee".
Well, I don't know if that is totally it, but I also understand that each engine is torn down to collect data. Unfortunately the engine is destroyed thereafter.
Yes, anyone who gets their engine replaced, please do ask. However I would only be interested in oil consumption engines. The 'ol no oil pressure due to a failed OPG is beyond repair for my practical purposes.
DCShelby
DC
Robert
I doubt it’s up to the manager or service writer to offer up the core back to you. The new engine comes from Ford, not the dealer. It’s not his to sell back and they would probably get fired if they did. It’s defective so they Ford, has no reason to give it back.
Narwaniec594
Chicago, IL
Peter
17 Gt350
My 2017 had engine replaced by previous owner. I looked at service records and shows at 5500 miles, had check engine light p0301 and p0316. Cyl 1 compression down 35%. They found Cylinder 1 intake valve spring broken and bent valve.
Hmm another valve spring...sounds like common problem on this topic
DCShelby
DC
Robert
Probably made from crappy recycled steel. If you make steel from scratch you can carefully determine its composition. So much steel these days is made from all kinds of recycled material of various grades and compositions, you never know what your gonna get. Just like Forrest said
