Recommended spark plugs on E85?
DaymienS550
Orlando FL
Daymien
2021 Mustang GT PP1
Im getting close to 20k miles and am gonna change the plugs out soon just as a precaution. Does anyone have recommendations for plugs that i could buy that will be used for running E85? I plan on going boosted in a few months as well so preferably ones that will also work for boosted applications if not no big deal ill just swap them again when i boost. Also are you guys gapping to stock specs? Thanks in advance!
HKusp
Hampton, Md.
Jason
If you're going boost I would check with your tuner, but I'm betting they say NGK 6510's and gap them at .028
DaymienS550
DaymienS550
Orlando FL
Daymien
2021 Mustang GT PP1
Thats what i was looking at. Will those also be fine NA for the time being?
GregO
Illinois
S550 GTPP
I’m thinking GT500 NGK spec. plugs gapped at .037ā€
HKusp
Hampton, Md.
Jason
The gap might be a little tight for N/A applications. If you are currently only coming up on 20K, in "normal" daily driven use, I believe Ford doesn't recommend a plug change until 100K miles, so you should be alright until you actually go FI.
DaymienS550
DaymienS550
Orlando FL
Daymien
2021 Mustang GT PP1
Even if I’m running E85 90% of the time?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Shouldn't matter.
The old points cars ran .28 to .32 plug gaps. I'm running .30 on my N/A GT. I think it makes the coils last longer and it will fire at 8000 RPM reliably.
GregO
Illinois
S550 GTPP
I’m N/A @ .032ā€ish smoothed it out from the factory wide gap. 50K miles on that gap.
But now the platinum grounded GT500 NGK’s #7 heat range have my attention.
FrankRussel
Kentucky
Frank
2020 Ford Mustang
F8S should be standard issue plugs on full E85 cars..97506 are good for pump gas but timing won't be clean as F8S on E85..
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
2016 GT vortech car with fore innovations fuel system and E85. I did NGK 6510 gapped at .026. No issues. Car has been running great the past year.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Shouldn't matter.
You want the widest gap you can get, it results in a more complete burn. NA means stock plug gap in my book. Boosted needs tighter gaps to avoid blowout.
K4fxd
NKY
Up to a point. If all you need is .024 gap and you use .06 you are just working the coil too hard. The wider gaps will blow out at high RPM if the coils can't keep up. .03 to .035 is plenty for a N/A engine
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
I get what you're saying but I don't agree that .035 is "plenty". Ford clearly had a reason to spec .050. If less was good enough they could have saved some money on coils. I agree its not going to matter much in practice, but I just prefer following the spec.
