Rear suspension creek, cannot solve the issue(solved)
nj888
New Jersey
Mustang GT 2018
Hey Everyone,
I have tried almost all the possible remedies I can think of but I am still getting creek/noise on the rear passenger side when I get in and out of driveway as well as going over some bumps. This is bad during the cold days anything over 75 the noise subsides, very minor. Here is the list of parts I have, the noise was there when I first got the springs and shocks installed, all other parts were after that.
BMR vertical links
Camber arm
BMR min drop spring .5 inch
Steeda active shocks
Things I have tried already.....
Swap the shocks from right to left to see if it was an issue, not the case
Checked the axle retaining nut, I tried with 200ft/lb on my torque wrench it did not budge.
Re-torqued all the bolts, vertical links, camber arm, toe link
Greased swaybars
I checked all the point did not see any play except the half shaft has minor play it moves slightly side to side.
Checked if rear seat has any issue, was not the case
Can anyone see if anything else is an issue. Any help is appreciated. Thanks
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
nj888
nj888
New Jersey
Mustang GT 2018
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Thanks for the info, can u use lithium grease spray?
You could try it. But fluid film has the properties for getting deep into crevices as it basically spreads itself out. You should be able to buy a spray can from any auto parts store.
nj888
nj888
New Jersey
Mustang GT 2018
Ok got it. Will give it a try.did you spray it from trunk or underneath?
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Underneath. Along both seams of the support beam identified by the red arrows in my picture.
If it’s not that issue noted above, then also try to check the rear diff to pumpkin bushings…. Stock rubber ones are known to rip/tear.
nj888
nj888
New Jersey
Mustang GT 2018
I checked and looked fine. Here is the pic, idk why there is two holes up and down, is that by design. Also only the passenger side has holes and driver side doesnot.
Dana Pants
Burlington MA
Dana
2018 GT PP1
nj888
nj888
New Jersey
Mustang GT 2018
So spraying the trunk area did not do anything but I actually sprayed some grease on the rear back seat that did some trick, no squeak on the bumps but I still get squeak seem to be from other area when I go in and out of the drive way.
JFBullitt
Atlanta
2019 Bullitt
I had a similar noise occurring specifically at low speeds. Appeared right after I did a morning out in the mountains. Thought it was my suspension or maybe subframe, but it was definitely the rear seat. Sprayed WD-40 on all the hinges and the noise disappeared.
nj888
nj888
New Jersey
Mustang GT 2018
OK, so finally this has been resolved. The back seats were the issue on these. I spray them with Lithium grease on all three points that the seats move or is attached and well the noise is gone. I was surprised that seats could make this much noise lol. All in all after lot of hours of checking suspension it was my seat, meh. Hope this help people have issues.
GrabberBargeCaptain
tomservo92
Conroe, TX
Black 2015 GT Premium
My car developed the rear squeak and I thought it was suspension related but then I found this thread. I put the rear seats down and the squeak disappeared. A few shots lithium grease on the hinges and latches fixed it. I'm glad I kept searching and found this super cheap fix!
