Brent Dalton
Sua Sponte
Yep, that was my fault probably due to my post a couple pages back.Didn't we already go through that there was no limp mode , just the warning?
Aren't we all. :cheers:This is good news. Hopeful it works.
I'm likely in, I would like to devise a passive system to cooling the diff vs. having to do coolers, pumps, and lots of pluming. I have access to CNC equipment, a very good machinist, aluminum welder, and fabricator if your guy stalls, please get in touch with me and we can pick up the project and get it done. I will wait to see where you guys end up before I move forward.Aren't we all. :cheers:
If he uses an OEM Cover, and custom fabs it...that will be the most cost effective route to take.
A custom Billet, or extensive cast low volume design is surely to be very costly.
As soon as I get something in my possession, I will share pics.
I have an Auto case that I plan on swapping depending on what happens with the 2018s. However that is mostly for weight, and the natual cooling properties of aluminum.I'm likely in, I would like to devise a passive system to cooling the diff vs. having to do coolers, pumps, and lots of pluming. I have access to CNC equipment, a very good machinist, aluminum welder, and fabricator if your guy stalls, please get in touch with me and we can pick up the project and get it done. I will wait to see where you guys end up before I move forward.
Has anyone done a front case swap to an all aluminum diff for track use. I am wondering if the aluminum front case would help to reduce temps vs the cast iron piece we have now?
