"Rear Axle Differential Temp Increased, Decrease Speed" warning
Gatorac
Chin Tack Days Event Mgr
Bradenton FL
Jim
2016 Premium GTPP Triple Yellow
Torsen diff in the Mustang. No clutches.
Gear oil stinks fresh out of the bottle. Really bad. Like you don't want to change it anywhere near your own house bad.
EXP Jawa
Rochester, NY
www.torsen.com
Rick
1999 Cobra Convertible, Electric Green
I thought the 15/16s did Not have clutches?
The GT models with the PP, which have a Torsen diff, have no clutches. All others have traditional multiplate clutch LSD, which is the case for GTP, who asked the question I was replying to.
Gatorac, If you think gear oil smells bad, try straight up friction modifier...:D
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
Sorry, I was just skimming over the info and saw 'clutches'
Gatorac
Bradenton FL
Jim
I'm gonna avoid the smell test on the FM and take your word for it.;)
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Oh boiy. I get to replace both next weekend. Think I'll tell the GF I need her help.
strengthrehab
Houston
Ken
2016 DIB Base GT with PP
I have a 16 PP. I'll be doing a track day in Houston in a little over a month. Car has almost 12k miles on it. Should I change the diff fluid to the 75-140?
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Its not a bad idea. FWIW, my car didn't have overheating issues with the stock fluid and about 6-8k miles, but changing the fluid seems like cheap insurance against having a track day cut short due to temp issues.
EXP Jawa
Rochester, NY
www.torsen.com
Rick
That would get my vote. The evidence does suggest that 75W140 is a better lube for that purpose that the factory fill.
strengthrehab
Houston
Ken
Yeah, the car will be doing 4 20-min sessions per day and I'm basically a newb as I haven't been on track in years and even then it was a fox body car.
I guess at 12k miles I should probably do the brake fluid and my oil will be ready to be changed by then, too.
MaverickGT
DFW Area, Texas
2016 Ruby Red GT PP
Is it MSR Houston Sept 24-25? I'll be there as well.
I changed it to 75-140 this weekend as I ran 75-90 in July and had temp warnings.
strengthrehab
Houston
Ken
Yes it is. Did you change it yourself?
MaverickGT
DFW Area, Texas
2016 Ruby Red GT PP
Yes I changed it. Get a hand pump that fits a quart bottle. I used Amsoil. Others have been using some stuff from Optimum Performance. Also change the brake fluid. At 12k its a safe bet.
See you at the track.
MaverickGT
DFW Area, Texas
2016 Ruby Red GT PP
Torque for Differential Fluid fill plug – 25 lb. ft.
strengthrehab
Houston
Ken
Is there a drain plug on the diff cover? and a fill plug?
MaverickGT
DFW Area, Texas
2016 Ruby Red GT PP
Yes, both.
