Properly Fixing Front Plate Holes
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
the body filler would have something to grab onto compared to just a straight hole though the plastic.
It will still sink. Sorry my man but u need to get to the backside to anchor the repair.
speedfrk
Atlanta
www.nationalsuperbike.com
Curt
2023 F150
My car is Oxford White. Can't get much worse than two black protruding holes in the middle of the bumper cover. I'll probably try to sand the smallest area possible down, fill, prime, and paint. If it looks worse than those black holes I'll be surprised, and I'll just take it to my body shop and have them fix it. I can't imagine that it'll look much worse even if the paint and fill isn't absolutely perfect. It's two black holes on a white car, doesn't get much more noticeable than that. Also have plugs coming but don't think that'll look great to be honest.
I didn't say leave the holes... I custom paint motorcycles for a living. I wouldn't even try to fill and paint holes if the car was mine and I'm pretty damn good at what I do. The color match on the plugs should be good with white. I'd put them in and give it a month and see how much it bothers me after that. You can use dremel with a tapered stone to grind down the raised edge so the plugs fit nicely against the bumper. It's amazing what people get used to given a little time.
aidanmeade
aidanmeade
SE Michigan
Aidan
2015 Mustang GT Prem. Convertible 2020 Ford Mustang Ecoboost Prem
Im going to try them but I'll still probably try repairing it. Like I said if it looks terrible, ill just take it to my body shop and they can fix it properly.
ORRadtech
Atlanta, Georgia
Also, isn't there a special process/product needed to get filler/paint to adhere to plastic bumpers?
I think that by the time supplies, paint, etc is bought you'll be into a decent percentage of a professional repair.
A few years ago I had a Harley front fender painted. It was two tone with a 3rd color painted pinstripe. It cost be about $250 and the paint was like $75/pint.
Personally I'd try the covers you have ordered and if I couldn't live with them I would at least get a professional estimate before I tried it myself.
aidanmeade
aidanmeade
SE Michigan
Aidan
My goal isn’t to have it factory perfect, although that’d be nice, I’m just trying to get it less noticeable than plastic plugs or 2 holes. Like I said I’m not going to try blending anything. If I just paint the two holes and small area around them and it looks terrible, I’ll just take it in and let them do it properly. I can’t imagine the paint color will be too different from factory to the touch up paint on a brand new car.
Dr. JL
2016 GT350R: GR227 and GR378
Done this before. Remove the bumper cover. Find an old bumper cover and harvest some plastic. Apply tape behind the holes and melt the sacrificial old bumper material in the holes. When cooled, cut away excess plastic and sand flush. Prime and paint with touch up paint. Wet/dry 800, then 1000 then 2000 grit paper will prep for a rubbing compound then final polish. The 3M 1/2/3 system works good for the final steps.
aidanmeade
aidanmeade
SE Michigan
Aidan
Exactly what I was thinking as for painting, but do you think the same result could be achieved using some kind of automotive plastic filler? I’ve heard regular old bondo doesn’t work great for plastic, so something like that would be closer to an actual plastic bumper piece.
aidanmeade
aidanmeade
SE Michigan
Aidan
Something like these:
J-B Weld 8237 PlasticWeld Plastic Repair Epoxy Putty - 2 oz. https://a.co/d/2ZdFNH9
J-B Weld BumperWeld, 25ml, Black https://a.co/d/hzGLFqY
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
Glue some smashed bugs over the holes.
DadzMach
2023 Mach 1
You need to get the backside, if you don't you'll see the repair sink over time.
But if you can live with that, go for it !
This^^^^^ you must put a patch of some kind from the back first. I used little fiberglass patches, filled in, sanded and had it blended. This was not on my Mach but on a previous SVT Contour.
If it’s not done properly it will sink.
ORRadtech
Atlanta, Georgia
That may well be the goal but your thread asked the proper way to repair it. Several people have tried to tell you the proper way and been rebuffed.
It seems the proper repair and your goal are at odds...
Good luck, hope you are satisfied with whatever you try.
aidanmeade
aidanmeade
SE Michigan
Aidan
Yes as I said I’m fine if it’s not perfect. Covers/plugs are not a repair.
2016S550
Shopping
The bumper plugs do a very good job of covering the holes. I’ve used them a couple times and would do so again vs complete repair.
