Procharged 2014 overheating issue HELP NEEDED
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Okay so i pulled the thermostat out today. (i had to cut apart the oem one so i could get the oring to seat/seal).
Started the car but didn't take it for a a drive but I did hold it at 2500rpm and the coolant still got to over 220 degrees. And it didn't take long maybe 2-3 minutes of holding that rpm after it warmed up
I am confused
Thermostat just controls the minimum temp, not the maximum. All this proves is that the thermostat is not the restriction, it's somewhere else.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Is the water pump turning in the correct direction?
K4fxd
NKY
K4fxd
NKY
With the T stat out it should not have got to full operating temp while idling. You have a flow issue. Unless the previous owner was an idiot and ran tap water for coolant, the engine is not old enough to be scaled up.
Look at the water pump, either it is turning the wrong direction or it is defective.
Procharged 5.0
Las Vegas
WILLIAM
2014 procharged mustang gt
water pump is turning the same direction as the crankshaft. Which to my knowledge is the correct way. And this has been an issue with two different water pumps. So i doubt that's the issue. but i appreciate the insight.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
The belt could be on wrong or he could have gotten a reverse direction pump.
Given the pump is in the center I can't think of any way you could put the belt on wrong to where everything will still run, but run the pump backwards. I'm sure someone could find a way though.
K4fxd
NKY
I have seen the impellers put on wrong.
The 4.6 water pump runs opposite of the crank. I don't know if that housing will fit on a coyote.
Seems like you have ruled out everything but the pump and the water jackets.
Veteran
Italy
2020 GT white
I’m no expert, but what if someone left a rag or a tool that has partially blocked the coolant flow ?
We had a similar problem on a machine at work, and it turned out the maintenance team left a rag inside the machine.
Basspro302
Ohio
2019 mustang gt
Maybe they did the old block filler in the water jackets.
Jackson1320
California
Jaxson
2015 mustang gt
I would pressure test the cooling system (you can get a kit on eBay for $40-$50) and then face the facts that I might have a blown head gasket
Procharged 5.0
Las Vegas
WILLIAM
Already did that. Test came back fine. No combustion gasses are getting into the coolant system.
