ShawnO
2015 Silver PP GT 400A
After much thought on the weekend I realized that on the last HPDE in my GTI I did trail brake to get the car to rotate on Turn 16. Seems like I was doing this last weekend but I can't be sure. It's quite the dance on that turn while trying to brake, downshift, hit the corner just right, etc...You therefore might want to experiment with the typical hard braking in a straight line, but keep on the brakes moderately through the first 1/3 of the corner (as you turn-in). Roll off the brakes slowly, so you initiate your turn while braking somewhat hard, and finish your turn-in under light braking. This keeps the front end loaded, increasing front tire grip and reducing rear tire grip. It also forces you to stay off the gas, keeping the differential open, which allows the car tomore easily rotate as well.
This may help you get on the gas even earlier, as you can get the car pointed more easily and unwind the wheel earlier while applying power.
-T
However, on the carousel it's another story. If you have any ideas besides drifting
I'm open to them. More camber is going to help and tires I'm sure.
Thanks for the advice
