Possible Venturi fuel tank issue
Pistol_91
Clearwater
2020 mustang GT
Does anyone know if the mustangs saddle tank is split evenly on both sides of the car? I may be having a venturi failure (pulling fuel from the passenger side).
Long story short, this morning on the way home, I had to stop and get fuel. What said 50 miles to E quickly turned into a 12 miles to E in the matter of 4 miles. Once it got to 25 miles to E it was dropping a mile every 5 seconds or so. Very quickly.
Once I filled up, the car only took 12 gallons. There's no way I'd still have 4 gallons left with 12 miles to E, would I? Doesn't make any sense.
I mean I could have a malfunctioning sending unit? The float arm is perfectly fine. I pulled it out about 6 months ago to inspect it for this same issue. Just never got around to it.
Thanks.
2016 Mustang GT PP w/ Voodoo
Yeah the passenger side has a level sending unit with the venturi pickup. Drivers side has the pumps and another level sender.
I’d pull em and see if they’re sticking or if they move free.
allfivefifty
Jaime
2022 Mach 1 HP
Have you checked if your car is impacted by the fuel pump recall? I saw that someone here actually had one go out while driving. I replaced mine since i didn't want to take the risk. When replacing i read some folks bend the level arm when putting it back in the tank.
daSNAK3
Cary, IL
Jake
2021 GT
Mine was doing the same type of shit, ended up replacing both sending units, even though I think it was just the driver side unit that was the issue... has been working fine since.
SBR70.3
Edmond, OK
2021 Mach 1, 2023 Explorer ST, 2019 GTI (back up track toy), 2026 Colorado ZR2
If it is the 2020 GT in his sig, it is in the recall.
OP, if you have never removed the necessary parts to access the pumps, there is no need to be afraid. Removal and replacing them is extremely easy.
John S
Novi, Michigan
2022 Mach 1 HP
I wonder if Ford is going to reimburse owners who have replaced their own fuel pumps, if and when they ever decide to follow through on the recall? There's no excuse for the one year plus delay.
svega26
South Texas
Sean
2020 Mustang GT
Same thing happens to me at 50 miles to empty
Pistol_91
Clearwater
2020 mustang GT
I have a DW400. I haven't had the stock fuel pump for quite some time. The recall was only for the fuel pump itself or the entire bucket and components?
I've checked the driver side float before and venturi hose and it was all good. I have never pulled the passenger. I will do that and see what I find. Appreciate it.
Unfortunately I just filled up the tank.... Lol. So I may be getting to this next week.
What wire/wires control the sending unit?
There's a connector on the passenger side hat. You can see where it is in my photo.
engineermike
La
2018 GTPP A10
My understanding is it’s actually debris plugging the venturi nozzle that’s the issue, so they replace the whole module. What’s interesting is that there is a tiny filter just ahead of the venturi nozzle which means the debris had to originate in the tiny space between the filter and the venturi block or from inside the block itself.
Pistol_91
Clearwater
2020 mustang GT
Yes on top, I'm asking if there are any connectors that are inside the tank. Doesn't look like it. Thanks.
Pistol_91
Clearwater
2020 mustang GT
So should I blow out the nozzle with some air or replace the entire thing?
Does anyone know how much fuel the passenger side holds or no?
NGOT8R
Adrian
2019 Bullitt
The driver and passenger side fuel saddles looked to be the exact same size to me when I pulled both caps and siphoned the fuel out before beginning work on the turbo install.
Pistol_91
Clearwater
2020 mustang GT
Ok. I would assume they would be, just wanted to confirm. Thanks
engineermike
La
2018 GTPP A10
The nozzle is only .017". You'd basically have to pop the venturi block out of the bottom of the bucket then force water or air backward through it. But if it's a tiny piece of trash, then blowing air or water might push it out of the hole but probably not completely out of the block. It will be tricky to clean it good, but not impossible.
It holds a good bit. The hump is higher than you'd expect. However, the PS venturi is always pumping fuel over to the DS saddle. I'm guessing if there's about 1/3 of a tank left, I'd expect the PS of the saddle to be completely empty and you're just running off the DS saddle. The fuel gauge averages the reading from both sides and applies a rolling average to dampen fluctuations.
