Fuel tank replacement
estreeter34
Dallas
Eric
2023 Mustang Gt
Anyone replace their fuel tank in an S550? If so how much of a PITA was it? Debating doing it myself vs paying a shop.
dirtwarrior
kentucky
Joe
2015 3.7 mustang
I drilled into the tank installing a roll bar. It is a major PITA. Buy a ebay tank and have a shop change it.
bankyf
Fredericksburg, Virginia
2022 GT500 CFTP
I pulled my tank to install a fuel system and honestly didn't think it was that bad. I did it with quickjacks on my garage floor. As long as the tank is close to empty, coming out was really easy. Going back in was a bit of a pain. You do have to drop the driveshaft and exhaust though.
HKusp
Hampton, Md.
Jason
As was stated, on a lift, not terrible, but if you have to do it on your back on jack stands, etc. it might be worth it to pay a shop to do. It should only be 2 MAYBE 3 hours labor, tops.
estreeter34
Dallas
Eric
2023 Mustang Gt
Thanks guys! My dumb ass hit it with the sawzall when cutting out my resonator to install an h pipe. a little tiny hole barely dripping. Anyhow, no lift and my old ass doesn’t feel like rolling around under it for 2-3 hours. Taking it to a local shop now.
ORRadtech
Atlanta, Georgia
If the damage or hole is small enough - why not use a product like this first - before spending hundreds of dollars and the labor time?
https://a.co/d/07pEzetm
https://www.jbweld.com/product/j-b-weld-tankweld
There’s also other similar products on the market for fuel tank repair…
I used JBWeld back in 1972 in the rust belt on the bottom of a steel gas tank to seal multiple pin holes. It lasted 3 years for me.
I also wonder if plastic welding would work?
In either case I would want the fuel to be below the level of the damage first.
VoR
San Diego
Vic
2022 Mustang GT
That is a bummer, OP. For others who may want to cut out their resonator, I used this Gear Wrench exhaust and tail pipe cutter and it cut through the pipes in maybe 3 minutes on each side. Super easy and fairly clean cuts.
GEARWRENCH Exhaust and Tailpipe... https://www.amazon.com/dp/B000M93OUM?ref=ppx_pop_mob_ap_share
bankyf
2022 GT500 CFTP
I have a very expensive tube of 3m epoxy along with the dispenser gun and nozzles made specifically for the type of plastic used for the gas tank. I might consider selling for a reasonable price if you are interested. I used it to secure some zip tie mounting point to the tank for my fuel system.
estreeter34
Dallas
Eric
2023 Mustang Gt
