Oil Pan change
snakeyes
NC
Chaz
2021 Shelby GT500, Performance Blue, Black stripes
So once again, I'm looking for opinions on something hope it doesn't turn into the shit show the tire thread turned into ...🙄🙄🙄
Anyone know of anyone that has installed one of these - or actually has one on their car - if so what's the verdict ...?
Moroso Mustang 5.0L Coyote Steel Oil Pan (1979-2004/2011-2021)
snakeyes
snakeyes
NC
Chaz
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I have limited experience with the pan in question. I currently run the 20574 drag pan. When I ordered it, the 20576 pan was in the box. The 20576 is the aluminum version of the 20571 road race pan you are looking at.
The drag pan and road race are the same externally. The difference is in the pickup location. The drag pan has the pickup and baffling at the rear of the sump, the road race at the front of the sump. The fit and finish is excellent on the aluminum version, not sure on the steel. Pan is same depth as stock, although wider at the sump. Zero clearance issues with larger sump, plenty of room everywhere. RR pan on left, drag on right.
Grimreaper
Dallas
2017 GT
Those do look worth the money from the build quality picture.
@80FoxCoupe did you have a reason to change pans from stock? Or wanted something more performance oriented?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
There is no baffling in a gen2 pan. I wanted more oil control and capacity.
snakeyes
snakeyes
NC
Chaz
More capacity - and plastic just makes me skittish thanks for the comments
cheeser
Colorado
21 Mach 1, 4Runners and RAV4's
The drain plug appears to be located fairly high…probably won’t make a difference in draining when cars up on ramps.
I believe someone also makes a replacement metal A10 trans pan as well
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Drain looks fairly high on the pic I posted? That's the oil level sensor port...
Biggsy
MD
Warren
'17 GT PP, '10 Tundra
I have read in the Track mustangs online forum that quite a few have used it for road course/racing applications. Haven’t seen too much about it here. Don’t know if it’s against the rules to link another forum
Ratical
Mid TN
Nathan
03 F-250 21 Mach 1
I am also looking also, kinda waiting to see the 24 pan design, believe I heard it will be metal.
Sig556
White18
North Carolina
Ed
2024 GT Premium / Iconic Silver 10 Speed Auto
If you are replacing the plastic pan go with the 2024 Pan. Ford changed pans for a reason.
