1st Oil Change
sakman84
CA
Adam
2021 Mach 1 Premium. 6MT, Blue, upgraded wheels
I'm intrigued about the Boron comment also. I dug up Blackstone reports from other vehicles, and Ford Full Synthetic 5w30 appears to have around 134 units of Boron. Motorcraft Synthetic Blend is at about 107 units. Regular Amsoil 5w30 shows 150 units. Blackstone's universal average Boron content is about 50 units.
Since the regular Amsoil OE stuff is about on par with other full synthetics as far as cost goes (and meets the Ford oil spec), I'm most likely going to be running this oil.
Do you have the Boron numbers of Mobil 1 ect?
OutWest
SF Bay area
2021 Old Person Special Mach 1
I spent hours looking over numerous threads on the coyote "tick" issue. I came away pretty convinced that Ford uses certain "friction modifiers" or additives for the factory fill. I also came across an MSDS for a Ford engine oil friction modifier, I think it was called "XL something".... I never spent the time to determine that Boron is the key ingredient, happy for "OutWest's" contribution here.
A friend of mine used Ceratec and it took the tick away, I heard it personally before and after, I rode many times in that car. It completely disappeared for him, this does not happen for everyone, so it is prudent to try and avoid the tick form the start. It is something I have thought about too for my oil change.
Thanks to Fishtales for providing a list of 5W30 Syn Blends meeting the Ford Specification
Actually it was from a poster in the UK who did an analysis of the engine oil that came from the factory vs the one at the dealership. He found the factory oil had a higher Boron content. That may be why Ceratec works because it contains Boron
Atlas1
Everett, WA
Actually it was from a poster in the UK who did an analysis of the engine oil that came from the factory vs the one at the dealership. He found the factory oil had a higher Boron content. That may be way Ceratec works because it contains Boron
the royal purple 5w30 you talked about earlier, do you know what the boron content is compared to the factory fill?
OutWest
SF Bay area
Coastal-Mach
Wilmington, NC
Anthony
2023 BMW M440i, 2026 GMC Denali, 2021 Jeep JK
235PPM
Coastal-Mach
Wilmington, NC
Anthony
111 PPM Boron Content
Charlemagne
Czech Republic (Europe)
Nick
larr12
Alberto
2020 Mustang PP1
I dont know about the boron thing (if it helps or not) but I just took another look at the oil analysis from Blackstone Labs.
1st oil analysis with the factory oil 224ppm boron
2nd oil analysis with Ford Motorcraft oil 148ppm boron
Edited because I searched Pennzoil FS 5W30 boron count. According to the webiste is 263ppm
https://pqia.org/pennzoil-platinum-full-synthetic-sae-5w-30-api-sp-motor-oil/
Coastal-Mach
Wilmington, NC
Anthony
I have a Blackstone kit ready for my first oil change in late summer of next year, if my car arrives in the spring.
Oil analysis is a cheap investment at $30 a sample from Blackstone. The detailed report is nice for trending possible issues that could be happening inside the engine.
From the oils tested it look like RP and Pennzoil have the highest boron counts.
Stooq
Poland
www.youtube.com
Bartosz
Mustang S550 Mach 1
I have just had 1st oil change in my Mach 1 after 1500km milage. Procedure done in authorized service station in Poznan, Poland. From what I was told they used Castrol 0w30 as this is currently recommended for Mach 1 in Europe since Jan 2021 (despite oil plug having 5w30 badge). Before Jan 2021 it was recommended to use 5w20.
