Oil change advice
Mach U
Scottsdale, AZ - Winter / Carlsbad CA - Summer
Ron
2024 Genesis - 2021 Mach 1(HP)
Did a full synthetic oil change at 1,600 miles just to get the break in oil out. Only have 4,000 miles now, but it’s been a year since last changed. Do I worry about miles or months? Note it’s garage kept and non tracked. Thanks
Mspider
Michigan
2022 GT
You worry about both, kind of whichever comes first. Once a year or x amount of miles is usually the best advice. However driving habits also play a factor into how often you need to change.
Rael
Grateful Member
South California
2022 Mach 1 HP Tremec
Miles and months both count. I change my oil (full synthetic too) every 3,000 miles or so, though many say it need not be done that often. I figure it couldn't hurt.
You're approaching 3,000 miles since your last oil change. I know little about the speed at which various oils age, but I suspect the year it's been for you is not a problem. (Does the oil still have clarity, or is it dirty black?)
So, change the oil in the next couple of hundred miles.
Rapid Red
Woodstock GA
Greg
OP the car will alert you, until then worry it will give you something to think about. :computerrage:
04mazdaspeed
Illinois
2022 Mustang Mach 1
I follow 1yr or 5k miles whichever comes first. This goes for my garage kept toys and dailys. Obviously, I hit the 5k quite often on the dailys. The Toys, I change every June. I dont drive more than 1500 a year on the toy cars.
Mach U
Mach U
Ron
Thanks guys - got it / good advice.
Arknsawchuck
Cabot, Arkansas
Chuck
2019 Mustang GT PP2
I'm like others have said, 1 year or 5k miles, whichever happens first. The car alert for oil change only goes by miles as far as I know so I wouldn't rely on that. Changing oil never hurts your car so since you seem concerned about it I'd change it. Nothing like peace of mind.
Zelek
Hutto, TX
2021 Mustang Mach 1
Since my Mach 1 is my secondary car, I rarely ever hit the mileage for an oil change. It's usually due to time that I change mine and the oil indicator in the car will also tell you that as well. Every time I check my Google Keep notes for oil changes, it's always near the 1-year mark when I change it.
murick
Prague, Czech Rep.
Richard
2021 Euro Mach 1, FJG, manual
I believe the app is timing it as well. My oil is clearly degrading simply by being in the engine, which sits in the garage :).
Paul McWhiskey
United States
Paul
2017 Mustang GT Premium w/PP
You are correct. Oil oxidizes all of the time. It just oxidizes at a higher rate at higher temperatures. There are many other things going on even when the engine is not running. For instance, the blow by products that mix with the oil and the water that is formed from heat cycles and humidity in the air combine to form acids that can corrode internal parts. I kind of liken it to the circulatory system of a man who moderates his alcohol intake, chooses a healthy diet, and does not smoke to a man who chooses to disregard those recommendations. They are both going to enjoy life, but one is most likely to die sooner. So keeping the internals clean by changing oil on a regular schedule adjusted to how you use your car is the "Healthy" thing to do.
I am not a doctor, but I did stay at a Holiday in last night.
boB
boB
2019 GT PP1
If I may add a question as well, are any of you adding some oil to the new filter before installing ?
I fill the filter as much as I can before installing it. Does it help reduce the time before oil flows to the engine on first startup? Maybe. Does this have any effect on engine life? Probably not, it just seems like a good thing to do. ;)
Rapid Red
Woodstock GA
Greg
I do it this way, one fill of the filter. Let it sit, oil will wick /soak into the media.
Look into the filter it looks dry. The media is saturated or could be said charged.
HoosierDaddy
Randy
As long as the oil life value is good (and it was reset at last change), not much harm can happen if not tracking the car.
