Ohlins Road and Track s550
shogun32
Northern VA
cool beans. I guess I shouldn't be too surprised the Ford casting is such a PoS dimensionally.
TicTocTach
DFWTX
Clair
2018 EBPP
Good shocks - actual good shocks - are almost always money well spent. Getting the shocks and springs matched is critical, and it's hard to beat a combo that is matched during manufacturing. Looking forward to hearing how they do over time.
Du_tch
Du_tch
Glendale California
Hovsep
2017 Mustang GT, 2012 F-150 5.0
100% agree with that bro. The car changed to a totally different machine after the Ohlins and Steeda sway bars. Well worth the money. I also no longer have wheel spin because of the heavier rear springs.
DivineStrike
Doomsday
Charleston
15 GTPP, 11 F150 FX4, 07 CBR600RR
What’s the furthest you’ve driven in a day with your new setup?
Du_tch
Du_tch
Glendale California
Hovsep
About 100 miles within a couple hours. 80 of that being going up past newcombs ranch at Angeles Crest highway and coming down and then some city driving. (los Angeles streets)
DivineStrike
Doomsday
Charleston
How much of a drop did you do with your setup?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
v8hgt
Cheshire, UK
Nick
Race Red GT PP Coupe
I found that the rear pp shocks had too little rebound for firmer rate springs. Even very slightly firmer Rate. Fast sweeping corners with firmer springs and stock pp shocks can actually be a bit dangerous. The fronts are much more forgiving to harder spring rates. Ohlins or indeed any other premium brand rear shock makes a huge improvement with some very slightly stronger springs. Personally for gt duties I don’t think the fronts need changing. The rear end needs a stronger anti roll bar and adjustable dampers.
Triton54
Delano Mn.
Greg
18 GT A-10 (mine) 17 GT pp, 6spd (wifes)
Not exactly sure. Out of the box it was really low so I raised it about an inch all around
Even the Ohlin's were surprised by the Mustang weight! lol
Check06
Socal
Evan
2016 Mustang P1X GT
Hey OP,
Was just curious how the ohlins were holding up after a few thousand miles?
baevid
Houston
2015 Mustang GT
Running 7 clicks seems pretty rough to driving daily. I actually run mine at 20 all around my BMR front sway bar at the softest setting. I have the Steeda rear drag bar and i want to swap it back to a GT PP or GT350 stock bar.
The Ohlins R&T (300F/900R) themselves are amazing though. Considerably more firm than stock or my numerous different shock/spring combos but they handle bumps and re-settle after it very pleasingly.
