Elp_jc
Many of us have done it with just the ignition on, and a charger hooked to the battery. Keep in mind BMS will shut off power at 45 min regardless of battery charge... but you get a warning, so look for it, and just turn the ignition off and back on quickly, and everything will keep going. On my car, it took about 1 hr and 10 minutes, so you know. Just make sure you update to Sync 3.4 first, or the new map version wouldn't show correctly on settings. I had to load the 1.19 maps twice, since I did it the first time before updating to Sync 3.4, and settings still showed 1.18. After the second map update (and Sync 3.4 already there), if finally showed 1.19, as it should. Hope this helps.The instructions say the car has to be running, but will it work if you put a charger on the battery or is the car running mandatory?
