Not impressed with steeda clutch spring
Grimace427
NoVA
2011 Mustang 5.0
I had to replace my clutch at around 40k miles. I had no spring for most of those miles. Correlation isn’t causation but I do believe it didn’t help matters that’s for certain. I probably had about an inch of play at top without the spring. Since the new clutch I’ve had the Steeda res definitely a difference in feel but not that much. So I’m happy with it.
With previous cars I was much harder on them and clutches lasted me easily 60k+ miles
65k miles on my no-spring 2011(same hydraulic system) with original clutch. Nary an issue with the clutch nor cruise control. Several dozen 1/4 mile runs plus the Texas mile and daily commuting through northern Virginia traffic.
TexasRebel
Gearshifter
2016 YZ GTPP - PP2
Even with the spring I find that every now and then I have to put a toe under the pedal and pull it out all of the way even when the clutch is fully engaged. I think it has something to do with the self-bleeding system.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Same.
Ltsrock
Denver
Keith
2017 GT350r Lightning Blue
I got the new one installed yesterday but won't be able to test it out until the snow and cold end.
The removal was just as I've whined about, came out with a twist and shout. I have no idea how I'd reinstall the original without creating some kind of special tool. The GT350 large spring gives you very little to "visegrip".
LIGHTNING350
NY
Eric
2018 shelby Gt350
I'd like who ever says it's a 5 minute simple install to come over, crawl into my drivers side floorboard and prove it. I bailed on it until I finish losing weight, fresh out of a Yoga class and feel like figuring out how this is so simple
YMMV
I have change mine so many times from being indecisive that I can literally do the swap in less then two minutes. The first time I ever did it though it took me much longer. At least 10-15 minutes to figure it all out.
I have had my car now for about 9 months and I'm still undecided what I like best. Stock or steeda or no spring. I think no spring is my favorite but unfortunately rolling like that I have like a half inch of play in the top of the pedal if you just touch it with your finger. So ultimately I don't know if that's harming anything so I keep going back and fourth from steeda to stock.
Honestly like stock just fine and I like the ease of clutching. The only reason I disliked it and changed it was 1-2 shifts are horrible.
If I can put it in for awhile without touching it I'm sure I could master that one to two shift after awhile and may go this route.
I also would like to try that one dudes idea with the toyota 60# spring - see how that is.
dman
ventura, ca
2017 gt pp lightning
that's...Tacoma, not Toyota. the company is Tacoma Screw Products. i swapped out my Steeda to try the 60#. only a slight difference. so close, i left it in.
it may be a little lighter but not like stock...I prefer some tension/point of engagement. dman
LIGHTNING350
NY
Eric
2018 shelby Gt350
Oh got ya. My bad.
I actually just took out the steeda spring that i've had on for about 1000 miles (got caught up in the hype of it) and put the stocker back on. Some will laugh but after about ten or so miles driving in city type driving with some open road bashing, I loved it. First to second was a little harsh at first but I got use to it quick in my 100 mile or so cruise. I also found shifting was more enjoyable with the stock spring. Plus I love love the lighter feel, its effortless.
I kept reading car reviewers, pro drivers and even talking to people who know how to drive on a professional level never change the spring or do anything with it. So I had to put it back in and try it again, I'm leaving it. You really do get use to it and the ease of operation is nice. This is my 10th manual mustang, never changed a clutch spring ever. I guess I won't now either.
Just my take though fellas , enjoy what you feel is most comfortable.
dman
ventura, ca
Oh got ya. My bad.
appreciate what you said. sometimes, there's too much traffic on the info highway...I didn't like the feel of "where is the clutch" in my '17. don't know if you don't go and for the cost, got steeda. I've driven several track cars with factory and really didn't think about it. more concerned with tranny/shifter mounts.
enjoy what works for you...each to their own. dman just realized I landed in Shelbyland! with the dual spring, might be
quite different from single spring GT's to begin with, but I've driven several 350's as well.
Ltsrock
Denver
Keith
Yes I'm not crazy about the feel of the steeda spring mod, starting from a stop sucks even more now and the 1st - 2nd shift is horrible for me, YMMV. When I get a opportunity I'll be putting my car back to the stock spring. As you said, it took me awhile to figure out how to remove the stock spring, I'm sure it'll be similar when I try re-installing the original spring.
LIGHTNING350
NY
Eric
2018 shelby Gt350
I agree and glad I don't stand alone on this. After putting the stock back in and getting use to first to second again it is great. The steeda in comparison is less smooth for me, actually in every gear it is. I have to let myself stop getting caught up in the hype of certain mods. Any mod you do is not for everyone for sure. Everyone's comfort with driving is different for the most part.
The first time I did the swap it may of taking me ten or fifteen minutes tops, now it takes me literally a couple minutes. Super easy though.
Hadelson
Allentown, Pennsylvania
Hugo
24 RTR Spec 3
Just installed the STEEDA Spring yesterday. Drove to work today in some stop and go traffic. It felt pretty good and experienced IMO smoother shifts
  • Like
Reactions: A7X
A7X
Toronto
2017 GT Premium Black Silver Stripes
That's my experience as well. I'm leaving my Steeda spring in.
tj@steeda
Timothy
Great choice :shock:
  • Like
Reactions: A7X
GregO
Illinois
S550 GTPP
Stretch it to 3.25” and double check the slave cylinder hydraulic hose attached to the master cylinder.
I like everything about the Steeda spring after I stretched it a bit.
