Not impressed with steeda clutch spring
GhostWolf
Africa
Admin
2026 Mustang GTD
Am I the only one who was pretty let down after installing the steeda clutch spring? There is a lot of play at the top of the clutch pedal now. The resistance does not feel night and day and it feels like virtually the whole length of the pedal travel that there is resistance that the clutch is engaging/disengaging. In other words it did not make it easier to find the friction point because it's most of the pedal travel. The clutch has 30k on it so I don't think it's the issue. I think the steeda part is just not as great as people have made it out to be. But maybe I'm the only one who feels this way.
Hey I know this post is ancient but did you ever find a solution for the lose play at the top of the clutch? I have the same issue
GhostWolf
Africa
Admin
2026 Mustang GTD
Stretch it out from 2.50" to 3.25".
You won't regret it.
Will this affect the function of durability? I asked steeda about it and they said it shouldn't have to be stretched at all but I also have loose play in the clutch pedal at the very top
GregO
Illinois
S550 GTPP
About 6 years of daily driving on my stretched Steeda clutch pedal spring and still going strong.
You’re correct, there is absolutely play at the top without stretching that spring.
GhostWolf
Africa
Admin
2026 Mustang GTD
Does it affect the linear feel? Also did you just grab both ends and stretch or did you stretch each coil individually with it without heat? I'm a metal fabricator so I can do whatever lol
shogun32
Northern VA
no. it's an intentionally weak spring. It's just there to remove free play and top-out the pedal against the mechanical limit.
fire up your coal-fired iron forge, don the heavy leather apron and put that spring on a medieval rack and stretch that sumbitch till it begs for the quick, merciful death blow.
sorry, I was imagining the scene from Braveheart.
GhostWolf
Africa
Admin
2026 Mustang GTD
Lmao. I'm Gunna go stretch that sumbitch out to 3.25 with my cold hard hands. Caveman style
526 HRSE
California
2017 GT350 Grabber Blue
I totally envisioned that
GregO
Illinois
S550 GTPP
Cold stretch, grab a couple crappy 12” adjustable square scales. One on the bottom full coil held with your feet, upper full coil scale held with your two hands. Gently pull up and sneak up on the 3.25” OAL dimension.
GhostWolf
Africa
Admin
2026 Mustang GTD
I'm thinking just using my fingers or 2 needle nose pliers and grabbing both ends. I don't have any square scales at home.
GregO
Illinois
S550 GTPP
Then use some metal flat stock.
You’ll want to pull it evenly as to not stretch it out of square.
Fingers and needle nose pliers are going to hurt when stuff goes wrong.
