TexasRebel
Gearshifter
- Mar 19, 2016
- between the mustard and the mayo
- 2016 YZ GTPP - PP2
not really. The lighter spring holds the pedal out. The only time it gets stuck is if it stops on dead center (pivot point and spring ends are colinear; no moment on the pedal, the stock spring does the same). The difference is, when he takes his toe away, his pedal falls back down.Well if your still having to pull out your pedal with the lighter spring like you state above, then your contradicting what your saying a bit. So like @Guarded15 said "better" would be an accurate word.![]()
