New PB in the 2020
TKM Conbread
NC
Eric
2020 Velocity Blue Gt PP1 1987 foxbody LSR ProMod 98mm
  • Thread starter
  • Banned
  • #1
Went out friday and made 2 hits and was able to get a new PB…. Was able to run a 5.91 at 122 …. Second pass went a faster .60 but shook the tires around 150 foot!!! Full Weight PP1 car..
Procharger D1x 18 psi
Built A10
Circle D converter
Fore tripple pump
Id1300
Stock motor
Still footbrake the car…
Over all had a great time, i think the car will go in the 5.80 range and i drive it all over the place…
TKM Conbread
TKM Conbread
NC
Eric
  • Thread starter
  • Banned
  • #2
Not sure if the Bell done anything to the blower, but the car seemed very aggressive than it did before… Also last time i ran it was in the 98 degree range… this night it was 75 degrees..
TKM Conbread
TKM Conbread
NC
Eric
  • Thread starter
  • Banned
  • #4
Thank you
andrewtac
TX
mark
F250. 2020 GT 400A
Thank you
Nice, trying to get back to run mine before they shutdown Baytown. What RPM do you launch at off the brake? Hope to be about what your running, I have a very similar built; except vortech.
TKM Conbread
TKM Conbread
NC
Eric
  • Thread starter
  • Banned
  • #6
I left off idle, and just drove into the converter for it to flash real hard….. i wish i had more time to play with diff stall speeds, but we was having a Race with our other cars… pretty sure the converter flashes 38-4000 rpm
andrewtac
TX
mark
F250. 2020 GT 400A
Thanks, mine flashes about the same. I'll give that a try.
I Bleed Ford Blue
North East OHIO
Do you have better axles and a stronger driveshaft to handle all that power? I see you already have a built A10 and sticky tires, just add a transbrake and that will get you 5.80's for sure. HP tuners has software update to add a transbrake on the A10, no extra hardware, wiring or switches needed, it uses the paddles to activate and use the transbrake.
TKM Conbread
TKM Conbread
NC
Eric
i have Dss 2000hp axles, and Dss aluminum driveshaft (wish i would have done carbon) PBD sent me the trans brake tune up, but i couldnt never get it to work… need to see if they will try and resend it
I Bleed Ford Blue
North East OHIO
there are videos on YouTube to show you how to use it.
TKM Conbread
TKM Conbread
NC
Eric
Mach1soldier
Cocoa Fl
Luke
2021 Mach 1, 2020 f150 EB
Car is booking! I have the same combo pretty much except no skinnies and 11 psi of boost. Curious to see what the skinnies do since I’m stuck at 6.53 with a 1.56 60 footy
vtknight
Canada
2019 Mustang GT
Congratulations - that is a solid run! That is a super solid MPH...A couple of questions; what power are you making? When you say built trans - anything beyond Circle D and clutch packs? (Midnight Performance etc.). Thanks and well done!
TKM Conbread
TKM Conbread
NC
Eric
last time i dynoed the car it made 964 but i could see where it started falling off up top… so now i have a 1320 ported Boss intake on the way to try, they suppose to pull all the way thru 8500rpm..
trans is clutch kit and i done a valve body but dont think i needed to… yes circle D converter 4c 3800-4000
