New PB in the 2020
vtknight
Canada
2019 Mustang GT
last time i dynoed the car it made 964 but i could see where it started falling off up top… so now i have a 1320 ported Boss intake on the way to try, they suppose to pull all the way thru 8500rpm..
trans is clutch kit and i done a valve body but dont think i needed to… yes circle D converter 4c 3800-4000
Thanks TKM - so - trans is just a clutch kit with the circle D unit. I have the 258mm - and I was unaware that the 10R80's have more than one stall version (I know the 6R80's do)? So you were 960+ on this run or you did the intake before making this run?
Much appreciated!
TKM Conbread
TKM Conbread
NC
Eric
2020 Velocity Blue Gt PP1 1987 foxbody LSR ProMod 98mm
Much appreciated!
Yea 964 is what she made in this run!!! Intake change will be coming soon!!!
yea circle D will change the stall speed for your setup!!
vtknight
Canada
2019 Mustang GT
Excellent - that is very good to know! I am looking at Midnight Performance to build the trans...
TKM Conbread
TKM Conbread
NC
Eric
They build some of the baddest
TKM Conbread
TKM Conbread
NC
Eric
New revision sent to me today, but for the Life of me i can Not get the TransBrake to work with the paddles….
doing it just like the videos..
Rob said it is turned on
I Bleed Ford Blue
North East OHIO
what drive mode are you using? it can be changed to whatever drive you want or all modes, but I believe it defaults to drag mode.
TKM Conbread
TKM Conbread
NC
Eric
I tried Drag and track Mode… neither work
I Bleed Ford Blue
North East OHIO
Did you get your transbrake tune from PBD? talk to them and explain what is going on, they might be able to help
TKM Conbread
TKM Conbread
NC
Eric
Yea from Rob i will
Mesg him and tell him shes not working!!!
I Bleed Ford Blue
North East OHIO
Your ordeal has gone beyond my knowledge level, you need professional help to get it working.
Decible
Georgia
Sam
2023 Mach 1 HP
Man that’s about a 9.3 @150 if you ran the 1/4. That’s flying.
Andy13186
Hold the left paddle and right paddle and the brake with your left foot then jab the throttle(but let off immediatly) with your right foot, then let off the left paddle and let off the brake, then you can rev up and then let off right paddle to launch I think. say bye bye to axles first though if they are stock and you hook lol
