Need some Drag help
Jrwimmer
Buffalo, NY
16 Mustang GT Competition Orange
I go almost every week to the track near me, it's only a 1/8th track but the best time I can get is a 8.9 @ 82-83, definitely want to to better without buying a procharger ect and it seems like it's possible but I'm not sure how
Currently I'm running
2016 PP GT
Corsa cat back
BMR rear toe links and vertical links
Barton shifter
Running on 19" 305 nitto invos
I have about 2000$-3000$ to spend, what's the best option?
I spin through second gear.
A tune? Drag radials?
Thanks for the help!
Jrwimmer
Jrwimmer
Buffalo, NY
Forgot to post, I have a manual, I'm good at launching, usually .5xxx and I slam through gears with this Barton shifter so that's not my issue,
Thanks again
66sprint6
Middle TN
2015 Base GT PP
Tune and tires will work wonders. I have JLT/catback/Lund E85 and run 7.9 @ 91 on street tires. Tune will wake it up and get rid of the clutch protection and the tires will make up for spinning at launch and on the 1-2 shift. Mine spins bad on the 1-2 and I have to try and shift earlier or pedal the spin a bit.
Burnin4
Mooresville
17 GT350
If I was trying to get the lowest ET's, these would be my next mods.....
Ditch the Barton for an MGW, install a hardened clutch cable, 1pc driveshaft, dss axles, and a tune from Ken Bjonnes, get everything from beefcake except the tune. I'd also get a set of Welds 18x5/17x10's with MT R's. I went 7.4's at 93mph in my 12 Boss & 14GT with similar mods (longtubes). Good luck!
Jrwimmer
Jrwimmer
Buffalo, NY
How does a tune work? You just buy the tuner plug it in? Sorry new to this!
Also could someone tell me the exact tires and rims to buy, getting confused on whether or not I want slicks or drag radials. And the size.
Jrwimmer
Jrwimmer
Buffalo, NY
My car is also lowered 1" on eibachs
Braski
Lancaster, PA
Traded 2015 Blk GT Prem PP on 2019 Corvette GS 2LT M7
Get some slicks and a tune. I run hoosier's and pp2 tune. I back into the water box, light them up enough that smoke starts rolling off, let off brake and roll out of burnout, stage, Rev to 5k and let clutch out when I see the last yellow light. I'm shifting just over 7k. I would recommend running skinnies. Here's a pic of my best run so far. I'm in the left lane and a new zl1 is the looser in the right lane!:first:
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
Before you do anything else. Get some sticky tires! Biggest improvement you can make at the track at almost any price.
Jaehead
Columbus, IN
2016 GT/CS
what's ur 60 ft time? i don't think u need tires yet.. with 305 nittos u should be good for 1.7-1.8 unless the surface is that bad
66sprint6
Middle TN
2015 Base GT PP
Tires are great but wont do much when clutch assistance shuts you down. It used to kill me on street tires and got worse with some sub-par Nitto NT555r's. With the tune now I dont have that garbage holding me back and NOW I can look for some traction.
Rhamlinii
Baltimore, MD
Ronald
2016 Mustang GT (Base)
Intake, header, e85, tune, thermostat, tire.
codywilson3
Athens,Tx
'15 Mustang Gt
i am also new and just bought a lund tune. what is the clutch assistance? This is my first manual, so will I burn the clutch up easier now? Especially since i taught myself how to drive a stick?
iketh
Orlando, FL
Keith
2016 Mustang GT
is this at high elevation? I was doing 8.4 @ 89-90 only a tune at 89 octane testing the engine and factory 235/50/18... 82mph sounds too low to be just the tune
[ame]
15gtRob
Tampa FL
Boosted 2015 Mustang GT
Here's my $.02. Get a tune (custom not just the one that comes with the tuner) This will maximize the performance for YOUR car where you are located. Since you are manual trans you will want a bias ply tire. Mickey Thompson ET Street R are AWESOME. A bias ply tire will load up and minimize shock to the drivetrain saving your clutch and trans from some abuse. A Tune and Tires will make a huge difference. If you want to take it further start adding suspension. With an IRS car less squat is better. When the car squats you are loosing momentum.
