sandbagger
tuner update
I did get with my tuner and he did state it was the torque management that he had to adjust on my 2011 because on the track the car Hooks harder than on the street thats why you can not make it happen
while your not at the track
First trip to the track it had the stock tune and never did it ...On my last pass that night I forgot to tune off the T/C and it spun and then it killed power but as soon as it stopped spinning in first gear the power came back on .. This problem I'm having now is a completely different feel...
Second trip to the track it had the Bama tune and it did every run but for my last run of the night ( 12.78 )That run I left at idle ..It starting raining and I could not back up that run ..
After that night I posted about the problem and was told I was not turning off both T/C controls .. So for my next trip armed with this info I was going try it again with both T/C systems off like I was told ..
Last trip to the track was also with the Bama tune and both T/C controls off , it did it every run but for the last run were again I tried leaving at idle .. The track was crappy ( street heat night with bad track prep ) .. It spun all the way in first and got sideways on the second gear shift and I let off.. Leaving at idle the car seems to have full power
I have called Bama about this and they said it is not possible that the tune would cause this ..He said my clutch was fried .. Well I didn't buy that my clutch was fried .. I been racing 4 speed cars for 45 years and I know when a clutch is slipping ..A slipping clutch is not going to cause the motor to bog down and rev slowly and then return to normal after you shift to second gear ..Banging third and forth gears the cars jumps and gets a little out of shape .. Slipping clutch doesn't do that ..
It feels more like the TB blade is shutting down or all four brakes are being applied...
