MT-82 Second Gear Grind/Pop-Out
Ghost50
Houston by way of Philadelphia
2019 Magnetic Metallic GT PP1
I know people have reported a second gear lockout at higher RPM but something I have noticed that started a couple weeks ago.
On my initial drive of the day, so right after the cold start, my car has developed a tendency for 2nd to grind and/or pop out. The weird thing is that is the only time I have experienced it - just after the cold start.
I do let the car warm up and idle down for several minutes until I pull out of my garage so I am not just starting it up and hammering it. Even after I get out onto the roads I don't rip on it right away.
ctandc72
VA
'19 GT 6 speed Base
Ditch the factory fluid in the MT82 for the BG stuff or Royal Purple. The RP made a big difference in how my car shifted and that was when it was only a few months old.
GregO
Illinois
S550 GTPP
Motul Multi DCTF and don’t look back.
BG SyncroShift II, is a proven product but I say Motul DCTF has the cold weather advantage. Plus Motul DCTF was engineered for 1200 HP track GTR’s
Ghost50
Ghost50
Before I got a chance to change the fluid it started doing it more frequently.
Yesterday it did it three times. Once in the morning - once on the way home after work and then I let it sit for two hours and took it back out and it did it again.
I dropped it off at Ford this morning. I have a feeling that it is the shift fork and/or synchros.
Ghost50
Ghost50
Update;
It’s the synchros at least for sure. I road tested it with the heavy line tech today and it popped out. New transmission on the way.
Fun times. This is annoying. 6000 miles and it’s toast.
Taylor1234
Jacksonville
Taylor
2018 Mustang GT PP
Did you have issues with 2nd locking up? To the point where you couldn’t even get it into 2nd? Im about where you are, 10k miles and I can’t get it into 2nd gear 20% of the time. Ill take a new tranny at this point. It is annoying, but my dealer is just saying it feels fine when they drive it.
Ghost50
Ghost50
No sir - no lock out. It drove fine as far as I was concerned. Nothing made me think that it was about to grenade on me. It whines a little bit in first at low speed but not loud or to the point where I thought anything was wrong. The shifts felt short and tight - I love how it feels in comparison to the older Mustangs.
It just started popping out of second one morning. At first I thought I didn’t have the clutch all the way down or something after the first time bc it only happened once after startup for an entire day.
Now it pops out more frequently. I drove it today for a few minutes and was messing with it, shifting into second slowly and keeping my hand on the shifter with light pressure to feel it and it wanted to pop out most of the time. So I went first to third for most of my drive.
Originally when I mentioned my issue to Ford they kinda said well let us know if it keeps happening. It did. So I took it in and the advisor rode with me and it didn’t kick out of gear. I left it there overnight and went back and had the tech ride with me and it snapped out of gear when I first shifted. He looked at me and said “yeah your synchros are toast”.
I’d recommend taking it back to them or even to another dealer if you have another reasonably close.
Edited to add - several times it would get stuck in reverse and I’d have to really yank on it to get it out. That would happen when backing into my garage.
Ghost50
Ghost50
Thank you for posting this. Also thanks for all your information you’ve posted in a lot of the threads.
I’m wondering if I’m going to end up having to open a case with Ford. I really don’t want them cracking mine open and rebuilding - I’d prefer a new trans altogether. With only 5000 miles I wouldn’t think that to be unreasonable to request.
I’m also preparing to be without it for 3-4wks and hope I can get a payment reimbursement from Ford.
Strokercrate
Usa
2021 Mustang GT 400a Black Accent.
Rise from the grave old thread.
Im having the exact same problem. Second grinds/pops out in my 2019.
Did you get yours fixed under warranty? They fight you on it? Give a payment reimbursement?
Brian@BMVK
Illinois
2015 GT - Sold
I had to have my transmission replaced for this issue. Gear and syncros were bad. Since yours is newer, I'd definitely push for warranty replacement but don't get your hopes up.
wireeater
Virginia
wheelwell.com
Rich
Shadow Black 2025 Mustang DH HP
Update;
That's the same millage when I had mine replaced on my 2019. Same issues,symptoms. It was no hassle to get it replaced. As long as it's an issue that can be reproduced they will warrant it.
Strokercrate
Usa
Thats good to hear. Im at 17k
Problem is every ford dealer around me is booked up atleast 2 weeks out..
silverbullet85
San Diego
2019 Gt
My 19 gts synchros were toast on the 2nd and 3rd gears, trans has 12k on it 6k of them supercharged. My problem is nobody has replacement parts that I need, 2nd and 3rd gear and synchros. It's at a trans shop now and has been for 3 weeks, dealer says they have no eta on the parts. I know calimer has the parts I need but he will only sell you a full built trans not parts. He said it's so bad right now ford is sending him mt82s to fix. I am trying to buy a good used spare to have as I believe I will continue to have problems
Strokercrate
Usa
Damn. This is my DD i can't afford that. They are covering it though? I also couldn't find parts. I have debated re building it myself as i have done a few trans in the past and doing it with better internals and clutch but can't find any internals for 18+. I thought about reaching out to calimer about parts but guess that is scrapped.
