Modifying As-Built Data Guide
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
I have it on my 2019 with the latest sync 3 update installed.
Chef jpd
Brooklyn, NY
I guess the reports of the APIM changing in MY 20 are true?
AngelDeath
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
Just did a bit of forescanning.
Disabled the no key honk.
But, there is no longer the GT Ford Performance splash screen in the APIM.
In its place in position D is a generic ford oval.
I tried every number and letter in the alphabet. No joy.
So, for the Mustang there is only the Pony emblem splash screen (and GT 350)
07D0 02 01 xXxX X?xx xXxX
? Is the modifier.
Try 0Dxx (Pulled from another model)
Chef jpd
Brooklyn, NY
Sadly, my factory setting was 06xx (pony animation)
Setting at 0Dxx shows a generic Ford oval.
WD Pro
United Kingdom
Lime GT
Chef jpd
Brooklyn, NY
This is the one I was trying to find.
Gonzo
AngelDeath
AngelDeath
CH, New Jersey
Look at these locations:
7D0-02-01
7D0-03-01
xxxx0Bxxxx--ST Ford Performance
xxxx0Cxxxx--RS Ford Performance
xxxx0Dxxxx--GT Ford Performance
xxxx0Exxxx--Continental
xxxx0Fxxxx--Navigator
xxxx03xx 04xxxx--Lincoln Black Label
xxxx04xx 05xxxx--Lincoln Presidential
xxxx05xx 03xxxx--Raptor Ford Performance
xxxx06xxxx--Mustang
xxxx07xxxx--GT350
xxxx08xxxx--Vignale
xxxx09xxxx--GT350
xxxx10xxxx--Ford Performance * Sync 3.2+ *
xxxx11xx 10xxxx--Aviator * Sync 3.2+ *
xxxx12xxxx--Explorer * Sync 3.2+ *
xxxx13xxxx--Corsair * Sync 3.2+ *
xxxx14xxxx--Nautilus * Sync 3.2+ *
xxxx17xx 14xxxx--Bronco * Sync 3.2+ *
(Pulled from 2020 Super Duty Sheet)
Chef jpd
Brooklyn, NY
Thanks guys, got the FP snake to stick with option 10.
The GT PP is gone.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
WildHorse
N/A or GO HOME
Puddintane
'17 S550
So this is what the hex line in the AB file actually looks like ;
1, 726-12-01 BCM/GEM Body Control Module / Generic Electronic Module (BCM/GEM), 014B, 083B, 55, Yes, 00000001 01001011 00001000 00111011 01010101, HU5T-14B476-HAB, , HU5T-14C184-AAK
Interesting.
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
I don't know the exact address, but if you open the "easy" BCM configuration, not the as-built, you will see an item called Tire Size, or something like that, and a numeric value. That's the tire circumference in millimeters. Apparently it's not exactly the mathematically correct value that you would derive from the nominal tire size, but it's quite close to it, within 2% or thereabouts. Increase or decrease that value by the same percentage by which your new circumference is smaller or bigger than the original one, and that's it.
You may get some DTCs after that, which will have to be erased. If you can't erase them, then you may need to do a PCM and/or TCM relearn.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Great. I'll check it out.
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
I took a closer look. This is it:
The stock GT tires are 255/40R19 front and 275/40R19 rear. This means a theoretical circumference of 2157.018 mm in the front and 2207.283 mm in the rear. The value stored in the BCM is somewhere in between.
I don't think it must be perfectly accurate, since obviously the real circumference will always vary to some extent due to tread wear and other factors. I think it will be OK as long as it's close enough.
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
Interesting.
01 4B 08 3B 55 is the only hexadecimal there.
00000001 01001011 00001000 00111011 01010101 is the binary representation of those numbers.
The HU5T... is a part number.
