Maximum Safe RPM?
Jetnoise
Raleigh NC
2018 GT Premium PP1, 70 Shaker Mach 1 stroker, 1967 F/B 357W, 1968 302 Vert, 4I 85 5.0 B&M Blower
In reading and searching I’ve seen people post they’ve spun 7500 RPM on a stock engine, tuned, typically with a better intake manifold.
Does anyone know what the truly safe limit to spin a stock internal, naturally aspirated engine is?
Also, what is the weak point? Valvetrain? Rotating assembly? Oil pump gears?
I’m sure it’s been posted, I just couldn’t find it.
I think Ford has already answered all your questions, but i’m Sure there is better advice here on G6
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Now did they blow their OPGs simply because of high RPM or because they were constantly bouncing off the rev limiter which tends to be a common occurrence on autox runs?
My guess is the latter, as pure RPMs (especially on an NA car) have very little to do with breaking OPGs. What breaks OPGs is harsh vibrations and harmonics caused by hitting the rev limiter amongst a few other things.
This. The best thing to do being NA is to set the limit well above where you want to rev (so you don't bounce on it) and get an ATI balancer.
EFI
Masshole central
5.Br0
Remember, the GT350 has the same exact gears in its oil pump...yet they rev to 8250 stock.
If you're breaking OPGs in a naturally aspirated stock 5.0 at 8000rpm it's not because of rpm.
EDIT: I should say in a near stock NA 5.0 at 8000rpm
armykyle1 [HACKED ACCOUNT
Gulf Coast
2018 GTPP premium
If you're breaking OPGs in a 5.0 at 8000rpm it's not because of rpm.
This right here
Shifting_Gears
South Florida
So what breaks the pump gears? What I have gathered is boost, spray or anything that alters the engines harmonics at high RPM.
When the gears break, are we talking bottom end destruction from debris and lack of oil flow? Or is it one of those things that when it happens, if you shut the motor down ASAP damage is usually limited to the pump itself?
The crank and rods are forged correct?
Bluemustang
2015 Mustang Base GT
I plan on having mine set to 8200 at least (so I don't bounce off the limiter) once I get the 18 manifold and shift at 7800.
Turbolag87
Toronto
My18 gt
its harmonics at high rpm that cause it to break.
BmacIL
Enginerd
Naperville, IL
At excessively high rpm yes, but the cars that break them when NA are bouncing off the limiter or inducing driveline shock back into the crank at high rpm. Boosted it's a different animal, as the crank sees MUCH higher forces.
ahl395
Allan
I rev to 8k, boosted with an 18 manifold. Personally I initially kept it below 7500 before, but after taking it up to 8k it just felt incredible and more than happy up here. Lots of people running them that high without problems.
But as with anything else, you never know. Rev it 100rpm over stock and it could break or you could rev it to 8500 without issue. It's always taking a chance modifying things. Take it from me, 6R80 failures are few and far between yet I've broken mine 4 times at reasonable power levels.
Crank is forged, rods are "sinter forged" IIRC. Basically, better than cast but not as good as real forged.
Generally if the OPG goes it's taking the engine with it.
Ghost50
Houston by way of Philadelphia
2019 Magnetic Metallic GT PP1
Good question.
I've got 1600 miles on mine and the few times I've let it rip I've shifted in the 7300-7500 range.
kz
West Chester, OH
Mustangs & F150
Good question.
That's great but of course 7500 is safe on a car that has 7500 (or whatever it is) redline from factory. What they're talking about is elevated redline on previous generation (15-17) Coyote.
Turbolag87
Toronto
My18 gt
ive hit 8k on my car a few times by accident. MY18 stop pulling around 7500 so i have to shift around 7800 at least.
V8EATR
MIDWEST
2015 GT PP
My car has been revved to 8k for the last 2 years, probably 8-10k worth, its fine.
65sohc
Fresno, CA
2016 GT350
When I had a Boss I read everything I could find about it. I once read that it is Ford engineering's policy to design a 600 rom safety cushion into all their engines.
