Maintenance on E85
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
you can't get e100 at the pump.
I just got a batch that is so far testing above E95. I cannot see a separation line.
Going to wait 10 more min and check again.
Ford says to run a tank of 93 every oil change to lube things. 1 OZ of lube every other tank of E85 won't hurt the O2's.
I didn't think you could get E85 in Canada.
Nitrofish
California
2022 mustang gt 301a
@wazslow thats good to hear I rather not have to use anything just seen a couple things showing cali e is made a certain way being 85-90 percent and is more dry not sure if there’s any truth to that just trying to learn since this is my first full e car.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
700 bucks a barrel.
running a tank of gas isn't off the shelf lube.
e95 ? cool story.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Where do you see the separation line at? It's been in the bottle for 20 min.
Stand corrected. That's some good chit right there.
stannypack
stannypack
NOVA
2022 Mustang GT
K4fxd
NKY
wtf lol can the tune event adapt that high
The tune considers 65% 100%. Unfortunately I had 1/2 tank of 93 in the car so I cannot test higher timing or different fueling. Maybe on my next fill it will still be this high. This station usually tests at 80%
stannypack
stannypack
NOVA
2022 Mustang GT
gotcha, I had Juggernaut make my E85R tune actually E75R to be extra safe and since my station tests at around 80
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Methanol still needs a lube. I also think ethanol needs a lube.
You do you.
Flex fuel vehicle engines never required additional additives running pump Ethanol. The engines didn’t use any different top end metals than straight gasoline engines.
Now, if running 99-100% Ethanol or Methanol, that may open a whole new discussion about additives?
Also, I’m not saying 2-4oz of MMO isn’t going to hurt anything FWIW.
Cory S
Bradford, NH
Cory
I myself would dilute that with 87 octane to 75% all day.
K4fxd
NKY
I wish I had a 55 gallon drum. I'd mix it with 93.
K4fxd
NKY
Cory S
Bradford, NH
Cory
6 more points of octane from the gas in the mix. Probably not needed but I'm OCD that way.
6 more octane “numbers” if you want to be real OCD…. :).
