Mach1 Parts Spreadsheet
Schwerin
Home
2019 Mustang
Jack4Mach1
Australia
2021 Mach 1
I have a standard 2021 Mach 1 and I want to order the parts for the rear splash guards that are fitted on the Mach 1's that have the handling option.
Earlier in this topic, there is link to spreadsheet of part numbers, and in that it has these as the parts to order for the rear splash guards:
Rear Splash Guard Shield (RH)KR3Z-6328370-AA
Rear Splash Guard Shield (LH)KR3Z-6328371-AA
Arch ClipsW714040S300
Arch ScrewsW715060S450B
U ClipsW714040S307
I contacted LevitTown Ford and they advised these are the links for the above parts
The part that puzzles me is this mention of the U clips.
No amount of searching on the LevitTown site can find part number W714040S307.
I asked LevitTown about this and they advise that no such part is required, which is at odds with the previous comments in this thread and in the spreadsheet.
Also in the spreadsheet, the part number W714040S300 is listed as Arch Clips, but on the LevitTown site that part is described as Liner Rivet.
Has anyone ordered all the parts for the Mach 1 Handling Option Rear Splash guards, if so can you advise what part numbers and quantity you ordered and if they were all the parts to fit the splash guards.
Charlemagne
Czech Republic (Europe)
Nick
@Jack4Mach1 This is exactly what I ordered from Levittown:
KR3Z-6328371-AA
KR3Z-6328370-AA
4x W714040-S300 (rivets)
4x W716195-S450B (screws)
4x W714205-S307 (nuts)
Turned out, I didn't need the screws and nuts at all as I used those on the car, but that may have been only because EU models have some form of small guard shield there that was hold by those screws.
Don't know if there's any difference between screws W715060-S450B and W716195-S450B, probably not. Get both and the W714205-S307 nuts and you'll be set. Ignore the naming, these small parts are used all over the car.
Jack4Mach1
Australia
2021 Mach 1
Excellent
Many thanks for this
I know that cars have lots of parts, but would have thought Ford could make it easier to work this sort of thing out.
Thanks again.
Wondering if you have fitted larger wheels and or tyres and if so any issues with clearance etc?
Charlemagne
Nick
There are no issues with clearance whatsoever with HP wheels, as they have great offsets. I can still put a finger between damper and tyre in the front, twice more in the back, plenty of room everywhere.
Seeing you're from Australia, you probably have that small edge guard there too, see photo here and here. So you shouldn't need the screws at all, just rivets.
Jack4Mach1
Australia
2021 Mach 1
My Mach 1 , indeed all Australian Mach 1's, do not have that odd small rear Splash Guard
Have not seen that before.
Charlemagne
Nick
Must be EU thing only then 😁 At least with HP splash guards it looks proper, should have been that way from factory.
Mjschneidy
SE Michigan
Michael
2021 Mach 1 HP, 82 GT Track Car, 73 Stroppe Bronco
Anyone have the part number for the grill emblem? Should be unique to Mach 1 due to matt grey finish
