Mach1 oil consumption concern
agmattocks
Unstabled Mate
Snellville, ga
Anthony
UMMC 026 - 2021 MACH 1 w/ handling package
Hey peeps I have a 2021 Mach 1 that i have to put in 2 quarts of oil every 1000 miles. Should I be concerned? It's a daily driver (well 3 to 4 days a week) and I do drive it. Let me know what you think.
RocketGuy3
2021 Mach 1 6MT, 2025 Cayman GT4 RS, 2025 RS3
That does not sound normal. I am not aware of any regular oil consumption issues with these 5.0s in any form, and I've never experienced such a problem in mine. Nor in the 2015 GT I had before. I've driven a combined 50K in the two cars... so not a ton, but never lost a drop of oil.
If you're still under warranty, I'd say get it to a dealer you trust.
Rael
Grateful Member
South California
2022 Mach 1 HP Tremec
Yeah, what RocketGuy3 said.
That seems like a lot of oil to lose. Even the Mustangs I've had in the past that did consume a lot of oil didn't need that much addition.
agmattocks
agmattocks
Unstabled Mate
Snellville, ga
Anthony
Thanks I just want to make sure before I go back to the dealership. I've had it notated with them a coupe of times so my concern is on record. They said they've "tested" the system and see no problems (I think they're being lazy). So i'll have to get my Shaq on and force them to do more.
Rael
Grateful Member
South California
If it's under warranty, suggest to them they should pay for the 6 to 10 extra quarts you need to properly maintain the system between oil changes.
MachNroll
East of Hawaii, West of Nevada
Doug
2022 Mustang Mach 1 Handling Package
Very nice looking car you have there! Have you popped the hood to see if there are any obvious signs of a leak are present? Around the intake manifold, valve covers, oil filter, oil pan, drain plug. Any odor of burnt oil after driving? 2 quarts per 1k miles seems like a lot.
Skye
≈39N
"Skye" Mach1 N2144
There is a procedure you can ask them to perform, as part of a warranty repair. If anything, the following will formally document the concern and get it on the books.
Ask them to do the, "303-00 Engine System, Oil Consumption Test". I'll summarize.
1. Interview the Owner
2. Review car for leaks
3. Inspect PCV valve for correct operation
4. Confirm proper coolant thermostat operation
5. Inspect spark plugs for oil saturation
6. Oil change, using one quart less
7. Run engine, check oil, mark dipstick
8. Add final quart, mark dipstick
9. Record mileage
Customer should then check oil once a week, or every 200 mi/320 km.
"When the subsequent indicator readings demonstrate a full liter (quart) has been used, record the vehicle mileage.The mileage driven should not be less than 4,800km (3,000mi for regular vehicles and 800km (500mi for Ford Performance vehicles."
While there is the 500 mi statement, agree with others: if you're driving the vehicle under normal road conditions, other than fuel use, loss of 2 quarts of anything in that short mileage is excessive.
When you have time, please keep us updated. Good Luck. :please:
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
Thats too much. These cars use a little oil but that is way excessive. They need to check for scoring or valve guides not right. I believe for Ford its 1 litre very 750 miles(still excessive, but tolerable for Ford).
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
Yeah that is too much. I burn 1q every 6K miles. So 1 qt between oil changes. I have 39K miles, daily driven.
