Limp Home Mode
Stang 19
Ca
2020 GT500 Ford Performance Blue
Mine has wrenched on me a couple of times. No reason found, but shut her off and restarted and shazam...magic. No codes. The wrench seems to be more for Fords benefit, not us. Gee, how the F did we ever get to the year 2020 without it before?
Andy13186
Mine did this today at a redlight actually I couldnt even go over 5 mph, had to pull over. Its actually done it twice on me, both times while sitting at redlights though. I pulled the codes with a bluetooth reader and p0103 and p0104. Looks like it does have something to do with the MAF sensor in my case. I cleaned mine a few months ago, I wonder if it got damaged by that. Im going to clean it again and if I still get this issue happening I guess I will replace the MAF sensor.
Zrussian13
Phoenix
I left the gas station once and when I went to get on it hard and it shut down and wrench came on. I pulled over shut it off and looked it over. Everything was fine so I fired it back up and nothing. 27k miles later that's the only time it happened. I love sliding around in the rain so I go puddle finding when it's raining out here and slide it around and still only happened one in the dry desert climate...
lacanteen
Louisiana: Cajun Country
George
I've done the limp home thing but it didn't involve a car. Luckily I haven't seen the dreaded wrench (yet). :)
Stage_3
MA
2019 Roush Stage 3
Damn, that sucks OP.
I hope you get it all sorted out soon. Hopefully the wrench light is just an "one off" instance.
RacinJason
Mississippi
2017 Mustang base GT w/PP
Since you aren't going to the dealer to get it checked, you should probably check the code and see what it means. Don't clear it just in case it happens again. If it happens again the dealer will have the codes and the count it happened to rely on when they figure out what caused the issue. It could be that Ford will make a revision in the factory flash if this is reported by more drivers because it is hyper sensitive. Then that revision could tune out the LHM in certain situations. Just depends on what caused it and if it is a failing sensor or something else that was mechanically wrong.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
A droplet or two of water on the MAF element can cause this. Not a big deal. Let it air out, or dry it off yourself.
NoVaGT
NoVaGT
Northern Virginia
2019 PP1 GT Kona
I drove home last night, and back to work this morning, with no issues.
Thanks for letting me vent when I was pissed!!!
Porsche Dude
North Vancouver BC Canada
Bob
2019 Mustang GT PP 2, 2004 Porsche Boxster S
The car seems to have some sort of issue. 100% stock, just got it's first oil-change, 6500 miles.
Driving to work, the power ended, it was rev-limited to 3K or so RPM, and the wrench light came on. In the middle of D.C. morning rush-hour traffic, it was quite disconcerting. Thankfully there was just a few miles left in my drive to work.
Oil pressure was fine (I did check the oil when I got to work, it's fine), temps were fine, A/F ratio was fine. I figured it rained all night long, and something that wasn't supposed to get wet, did.
Ford Roadside Assistance is sending a flat-bed, and it's being taken back to the dealership I bought it from.
Just venting. I'm a little irritated.
I had this happen to my PP2 several times going downhill in traffic. It would go into limp mode and I would pull off and stop the car, wait 5 minutes or so and start the car back up. The car reset itself and all was fine. After 12 of these interruptions my dealer decided to replace the PCM. When pulling the data out of the existing PCM to transfer over, Dave found a performance code inside that was installed by the factory that GT's don't have, which was a surprise to all of us. I guess the car has more over a GT than just suspension and chassis. The PCM swap seems to have solved the issue.
Alberta Canada
Charlie
2015 mustang Gt 6spd convertable preimium , 1996 S10 , 2001 S10 , 2018 Honda civic touring
is it in valet mode or student mode ?
NoVaGT
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Nope;
Update.....it's been fine. Don't know what the he double hockey sticks the problem was, but it's sorted itself out.
