Bad E85 cause limp mode?
Corroeric
Oakland,CA
Eric
2021 Ford Mustang GT
Can bad E85 cause the car to go into limp mode? My tuner is saying its bad fuel but i tested it before pumping and tested at E83.
Proshop
Billy
Check engine or wrench light? If check engine what code(s)? Did you run e in the tank before if so what did it test?
Corroeric
Oakland,CA
Eric
It had a check engine light and while I was at a stop light the wrench light came on. Been running E85 for the past couple of weeks. It tested at E81 last fill up.
Proshop
Billy
Highly doubt it’s bad gas then.. did you check to see if any new codes popped up since cel was already on? Have you disconnected the battery and reset the computer?
Corroeric
Oakland,CA
Eric
Yeah I was getting code P061A and P061B. I was told it was my cai and I replaced it and now its bad fuel. I havent disconnected the battery.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
It's your tune, your torque tables are wrong.
Corroeric
Oakland,CA
Eric
I'll tell my tuner to check those out and see what he says
K4fxd
NKY
The easy fix is to raise the allowable error, the correct fix is to tune the tables.
Corroeric
Oakland,CA
Eric
He said it’s not the torque tables. He runs same tq tables on every other car with same set up
South Florida
Zack
21 Mustang GT
When does it go into limp mode? During WOT pulls? lower in the gears or usually up top will it kick the light?
Corroeric
Oakland,CA
Eric
It goes into limp mode when I'm at a light. Never at WOT or while moving.
K4fxd
NKY
Most times it's in the torque tables. I hate it when tuners say every car I tune runs XXX and yours should too.
He should ask for a data log with torque errors logged. If he has I apologize.
Corroeric
Oakland,CA
Eric
He didn't ask for a torque error log. He did ask for an idle and rpm climb. While I logged the car it went into limp mode again and was able to capture it on log. Hopefully he can see the issue.
K4fxd
NKY
If you have the ability to log, log IPC wheel torque errors.
