Tomster
Beware of idiots
My Shelby may have hit 166 mph at 7,800 RPM in 5th. Not sure how much it had left.
I think it had a few MPH more left in her.
My statement is still accurate. 6th is tall but there's enough power to pull it if the car had a lower CD.I thought that the maximum speed of the GT350 was at max RPM in 5th gear. So the problem isn't power, it's gearing.
Am I remembering this wrong?
That is exactly correct. 5th gear at 8250 is all she has. I was very close to 8250 if not there. Going that fast, I have my display set to TPMS sensors not MPH. There was a BMW that blew a tire on the front stretch doing 140ish and I have no idea how he kept control of the car. Anyway, by the time you get near those speeds at Daytona (170ish), its time to get on the brakes in preparation for turn 1 of the Rolex course.My statement is still accurate. 6th is tall but there's enough power to pull it if the car had a lower CD.
That was Van Collier I believe. Great guy and a heck of a driver.There was a BMW that blew a tire on the front stretch doing 140ish and I have no idea how he kept control of the car.
My 08 RS4 can hit @169mph, limited. Some of the guys have removed their limiters an @192 is reported. That's 420hp. The R is probably a little slower than the non-r due to aero but I really wonder what the top speed is... soon. ;) gearing limited, is the only thing.The fastest I saw was 175.5. Not much left. My guess the 350 max speed is 180
Exactly. Gear and distance limited. Switch up the gearing, get a longer stretch, and the horsepower vs drag is the limitating factor.My 08 RS4 can hit @169mph, limited. Some of the guys have removed their limiters an @192 is reported. That's 420hp. The R is probably a little slower than the non-r due to aero but I really wonder what the top speed is... soon. ;) gearing limited, is the only thing.
So are you saying that the CD of the GT350 is poor? Do you expect the GT500 will have a better CD than the GT350?My statement is still accurate. 6th is tall but there's enough power to pull it if the car had a lower CD.
According to my analysis, 5th at redline is 175mph, which is top speed. Shifting to 6th @ 175 drops RPMs to 5200, which drops power from ~460 to 370, which cannot overcome the drag.My statement is still accurate. 6th is tall but there's enough power to pull it if the car had a lower CD.
According to C&D, the ZL1 with the A10 hits 195 MPH in 8th. I would think a GT500 with the predicted power discussed here would be able to top that as is?So are you saying that the CD of the GT350 is poor? Do you expect the GT500 will have a better CD than the GT350?
I think if the GT350 had another gear between 5th and 6th spaced appropriately to put the engine in its power band it would have a faster top speed.
I'm sure the GT500 will make more power than the GT350 and if it has a 7 speed DCT it will definitely exceed the GT350's top speed. I would expect the car to have more downforce than the GT350 and I would be surprised if the GT500 can hit 200 mph unless some of the aero bits are removed.
Still have friction from the tires slowing the car down....or, you and drive it in a vacuum using bottled air...it may get up to 278 MPH in 6th at redline...
The S550 as a whole isn't that great for CD, and the GT350 is worse. It's done for good reasons: aero performance, cooling, etc, but it's not a slippery car. A 911 is much more so, for instance.So are you saying that the CD of the GT350 is poor? Do you expect the GT500 will have a better CD than the GT350?
