Zombo
befejezett
Yes, but tire friction wouldn't be an issue, with nearly all the HP available to overcome that...wonder how exhausting into a vacuum would work? I suppose the intake air would need to be regulated at a very low pressure, but then you wouldn't have the proper amount of mass to make the HP. This is what you do - you hook the exhaust up to a capture tank maintained at 14.7psia using a pressure bladder, bleed off the exhaust to the vacuum via a pressure relief valve, and regulate the bottled intake to ~14.7psia. That's the trick...
