HP Limit!?!?!?
2-tone
Cincinnati
15 mustang gt m6
You can have your tuner move the rev limit up that high. I'm not sure how "safe" it is in a boosted application with the stock rods at that rpm. I shift at 7400 soft rev limit at 7550.
silentbob420bd
silentbob420bd
Silentbobftbd
Littleton, Colorado
Estevan
2016 Mustang GT (pp)
Reasonable enough, I think I'll do that till i get rods and pistons. How hard was the Install, I love to do Installs myself I find it to be a big part of the fun.
ahl395
Allan
Just chiming in here
Here's a guide on installing the OPG's on a 11-14 model coyote. Extremely helpful, only a few things are different on 2015+
Link blocked, just google "How-To-MMR-Billet-Oil-Pump-Gear-s-Install-**A-FEW-PICS**" first result.
Another helpful thread 2015+ based
http://www.mustang6g.com/forums/showthread.php?t=30869
Timing procedure on 2015+, which is different from 11-14 in the first guide above.
http://www.mustang6g.com/forums/showthread.php?t=39249
beefcake
Bethel
2018 Ford Mustang
700 is about the most we like to see on pump, and that is getting after it. 800 on race gas / e85 is getting after it as well
some will obviously push the boundaries, but be prepared for a rebuild :)
Barrel
Hoonigan
Cars and Trucks
Well I'm at about 800 depending on the day and I'm about to do a rebuild on my motor, so that's about where I'd expect to see failures.
Tommy V
Brookly park Md
Tommy
800 rwhp is well over 900 chp which is a shit load of hp for a stock motor.My opinion,yea it will hold up for a little while,but eventually somethings going to give.These are very well built motors but at that point u are asking a engine to be reliable with over double the (rwhp).I dont know any of my buddies putting out that kind of hp that has not had to open their motor up.I guess it depends what your goals are,but if u think your motor is going to last for 5 years at that kind of hp level,u will probably get surprized.
JadedGT
Houston, TX
benkressler.clickfunnels.com
2016 Mustang GT Murdered out
Mine will be soon hitting 700 on the stock motor and not planning on pushing past that for now. If I want to go past that will plan to build a motor for it.
silentbob420bd
silentbob420bd
Silentbobftbd
Littleton, Colorado
Estevan
I'm looking to be around 850 crank when all is said and done, so around 700 wheel is pretty close to on spot for what I'm wanting. So does anyone know if there is a good flex-fuel tune out there? (If I were to do e85 that would be my route because of my earlier stated reason, couldn't and wouldn't be able to run it for very long. Maybe a couple of runs at a time.)
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
You will need 2 tunes with a supercharged car. An E85 and 91 tune. I am not aware of any flex fuel tunes with a power adder.
I live east of Denver. If you look around you will see we have E85 everywhere up here even at the track.
Livernois Motorsports
Dearborn Heights, Michigan
www.livernoismotorsports.com
S550 HQ
2016 Mustang GT (TVS 2650) (6R80)
We offer a KILLER FF tune! You can load your MyCal tuner with upto 4 custom tune files AND your stock file at the same time! You do not need 2 tuners. With our FF tune you can use 91, 93, e85 or better! No tune swapping needed!!!!!
