M-Driver
Again something I've never heard before. So a built engine won't be bulletproof on long runs?Coyotes are known for pumping the pan dry on long pulls. Don’t think 10 quarts makes you safe
Depends on if you suck the oil pan dry. The heads can take up a lot of oil and it takes time for the oil to get back in to the pan. A built engine normally would not have to worry about it because if the engine builder knows what they are doing they have increased the oil drain back.Again something I've never heard before. So a built engine won't be bulletproof on long runs?
Well, wouldn't that be a problem vor N/A GTs as well? I ask, because we never had someone without supercharger reporting a damaged engine from long top speed pulls, which is possible on unlimited Autobahn sections.Depends on if you suck the oil pan dry. The heads can take up a lot of oil and it takes time for the oil to get back in to the pan. A built engine normally would not have to worry about it because if the engine builder knows what they are doing they have increased the oil drain back.
I was not sure if it be or not. but 10 qt's are better than the 302's 5qts.Coyotes are known for pumping the pan dry on long pulls. Don’t think 10 quarts makes you safe
Blowers pressurize the crank case more than n/a ever would. the pressure wants out and out is the pvc that is at the top. air flow going up doesn't help gravity get oil to the pan.Well, wouldn't that be a problem vor N/A GTs as well? I ask, because we never had someone without supercharger reporting a damaged engine from long top speed pulls, which is possible on unlimited Autobahn sections.
Any oil consumption issues with your drive style?I think you definitely need really great octane with these motors. And a cooler higher octane fuel like E85 is probably why mine is alive. I beat my car daily hitting over 8k rpm like 20 times a day lol. I just drive for fun and for some reason my car loves it, only ~7k miles supercharged at 750+ rwhp so far though but 47k miles of pure abuse but perfect maintenance, ceratec, keeping oil topped with amsoil , and e85 and no cats after going supercharged. Stock gen 3 motor with no OPG's. Knock on wood. Also I get 8.8 mpg
Yes it uses oil, but I am not surprised considering how I drive it. I add about .75 qt per 1k miles. I check the oil every ~500 miles and just keep it topped. Oil life is down to 5% within 3k miles using the oil life reset monitor. I think I would have blown this motor years ago if I never checked my oil and went like 3k or more miles between changes while driving like this.Any oil consumption issues with your drive style?
I’m guessing now that the GEN3 is using coated aluminum cylinders the traditional iron bore ring end gap rules change. I say this based on my days spent with powersports engines switching from iron liners to Nikasil or some other equivalently coated aluminum bore.Regarding ring gap, I had always been of the mind that you needed more for forced induction. Per wise o instructions decades ago, I typically ran up to .026 in the top ring. My spare Gen3 short block is totally stoc except I gapped the top ring to .018-.020.
However, I have my doubts about this. Ford GT only runs .008-.010, predator runs .008-.012, while Coyote spec is also .008-.012. The cobra jet is .018-.020, which is why I chose that for my own.
It was also pointed out to me that most ring land failures are actually caused by knock, not end gap. The ring land area is the the most likely place for knock to happen since that is the last place the flame reaches.
Jesus almost a quart per 1000 miles? RipYes it uses oil, but I am not surprised considering how I drive it. I add about .75 qt per 1k miles. I check the oil every ~500 miles and just keep it topped. Oil life is down to 5% within 3k miles using the oil life reset monitor. I think I would have blown this motor years ago if I never checked my oil and went like 3k or more miles between changes while driving like this.
TBH I am kind of surprised that it doesn't use more. I had an 09 cts-v with 90k miles on it that would use about twice as much and catch like a half pint per 1k miles in the catch can but still ran great and made great power. I hit 178 mph in that car still my fastest I've been.Jesus almost a quart per 1000 miles? Rip
Did you leave it on the edelbrock file? I also have an edelbrock blower and it cracked pistons 5, 6, and 8. So I did some research and found that their file is known to break engines. Rebuilt the motor and working on getting it tuned right now. Thing is a monster.You should be aware of what might happen. In 11/2019 I got the Edelbrock TVS 2650 Supercharger Kit (Stage I) with 700 crank horsepower. I switched to 5W50 oil and installed the MMR Cylinder Cooling mod. Long story short: In 10/2021 after 22.000 km I wrecked my engine. Cylinder Nr. 6: zero compression, Piston cracked, cylinder sleeve and head damaged.
I never took my car to a racetrack but I drove it hard on winding roads and did some hard pulls on the Autobahn up to 300 km/h. The coyote did not like that. I guess it depends on your driving profile. If you plan to use the power regurlarly, you should better have some dollars in reserve for the worst case, quite enough to go for built coyote. That´s the way I go right now.
