Hoods and cooling....
illtal
I don't really like visual mods on my mustang (outside of wheels and tires), it sort of has a presence that I like stock. However, I'm of the mind that the engine compartment could use a bit more airflow.
I basically only have two viable options, the cervinis GT500 hood replica for the 18+ or the low cowl cervinis cobra r replica hood. I have been swinging back and forth with my own thoughts, and I really dig the look of the cobra r hood, since I was a child I listed for that car along with the FR500 back in the day. But likely the GT500 replica hood will cool better (bigger hole).
Does anyone know the advantages of a cowl hood with the rear heat extractor? Am I overthinking this or should I just be drilling/boring out the stock vents so they work better?
illtal
illtal
So I'm supercharged, I think I'll try opening up the stock hood vents. And getting rid of the blanket. I'm not keen on cutting up a perfectly good hood....
illtal
illtal
What's happening with the stock hood if you replace it?
Hot as hell in the engine bay ...
Hmmmm. I want more airflow. Gonna see if I don't have to go much farther than a little cutting under the stock extractors
If I don't like the results I always fancied the way the stock gt350 hoods looked as well. Mp concepts makes one of these as well.
IrishStallion
Missouri
18 gt mustang
I just used a 1/2 inch drill bit and opened my stock extractors on my 18. I like the stock hood. You can see the heat waves coming out now when stopped. Very quick and easy mod to do imo.
illtal
illtal
Do you have any pics? Did you leave the rain shield in or no? I forgot all about doing these things. Also did you remove the blanket?
IrishStallion
Missouri
18 gt mustang
I removed the blanket just to get to the extractors. Popped out the plastic vents and then drilled the holes into the aluminum hood. Once you pop the vents back in you cannot see the holes. I then put the hood blanket back on. Did not see any reason to leave the blanket off as there is not much weight to it.
Another thing I did is pull the rubber strip off the back underside of the hood which seals the cowl area. This lets a lot more heat move out from behind the back side of engine. I pulled all those white plastic t pins off the hood to. fyi
Jordan @ Lethal
Wellington
www.lethalperformance.com
Jordan
2016 Stingray M7
I would think all of these should add up to at least some cooling. Have you noticed the any heat waves leaving the from the rear cowl where you pulled the rubber?
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
if you guys are opening up your vents and removing your fire shields from the hood, how are you keep water from getting on the engine from rain? my fire shield on my hood is still on, it absorbs the water when it rains. I have 2016 California Special vents with the turning signals in them.
Dominant1
Dr Frankenstang
illtal
illtal
There is a rain trap on the 18+ hoods. Does the 15-17 have those?
Andrew@Lethal
West Palm Beach Florida
Andrew
Both would have heat dissipating. It would come down to which style you prefer.
Dominant1
Dr Frankenstang
No they do not..the water gets absorbed into the hood fire shield material, which is why i wont remove it!
