GT Rear panel... how should you maintain it?
danno1
CT
2019 GT PP2
OK
I do keep the rest of the car highly clean and waxed. But it seems the rear deck lid panel is VERY prone to scratching. Being its plastic what tips can I take to:
1) Wax/Polish to protect finish
2) Can a spray can of clear coat protect from scratching?
3) How can fine scratching be removed?
opengl
PA
2018 GT PP1 400A 6MT
Don't touch it.
Tell others not to touch it.
No automatic car wash (but you shouldn't be using those anyway)
Close the trunk by the spoiler or the trunk lid.
DON'T EVER TOUCH IT.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Buy a replacement and have it wrapped with ppf. Problem solved lol. Imo the biggest issue is sun and heat softens the plastic to where the gentlest microfiber will scratch it.
kluke15
Reno, NV
Kenny
2017 Mustang GTPP
i wrapped mine in carbon fiber wrap. keeps it protected and changed the look a bit.
mustangdriver
Illinois
Jim
2015 Mustang
I had good luck removing light scratches with motorcycle windshield polish. Do not
use any type of aggressive rubbing or polishing compounds or sandpapers.
DFB5.0
Australia
Mustang GT Fastback
The plastic surface of these rear decklid panels are extremally soft. This problem is not limited to Mustang's, all cars with these sort of surfaces are prone to micro-marring.
While a wax/sealant/ceramic coating will help make cleaning easier and therefore safer, they will NOT protect the surface from being scratched, even with correct/careful washing.
Spraying clear coat will not work either unless the whole panel is painted black.
As mentioned, the only real solution is to apply PPF to the panel, or buy a spare and have the PPF applied and swap it over. PPF can also mask some minor marking.
In both cases, you will need to polish the panel first before applying PPF. Try something like Sonax Perfect Finish or Meguiars M205. The panel will actually correct very easily but keep in mind, even the softest and plushest towel can induce marring, so work carefully.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
wadewolf76
Kansas
Damon
67 Mustang coupe, 21 Twister Orange GT premium
Mr. Met
06 Time Person ofthe Year
NYC
JJ
2020 GTPP Premium, 2015 GT Premium, 1999 Expedition EB
Yes, Xpel makes a precut piece for it.
danno1
danno1
CT
2019 GT PP2
So do you call them up and order just that piece ? Is it hard to do it yourself?
Mr. Met
NYC
JJ
As @Nardly said, it appears, at least online, to only come with the trunk lid kit. You could try giving them a call/email to see if they could sell you just that piece.
As far as how difficult it is to install, you will get a range of opinions. I had my ppf done by a professional. It would never come out perfect if I did it, and its not a cheap material to make a mistake with. Ironically, my deck lid panel is the only piece of the car without ppf as I had to remove it to change the emblem.
Also note, a shop, at least the one I used, doesnt order kits from Xpel, they "print" the pieces on site. So their prices are lower then what you see on Xpels site (retail) and they can make/install any piece you need.
