Gen 6 Whipple/VMP released for S550
robvas
MI
2011 GT
780hp is crazy for only 4oz of boostane + 93 on a 3.875 pulley
engineermike
La
2018 GTPP A10
Not totally surprising at 12.5 psi boost and 20 deg timing. FYI it appears as most of the gen vi (and 2024) magic is actually coming from higher timing and boost.
robvas
MI
2011 GT
crossing my fingers that they do a video where all they swap is the headunit and go from gen 5 to gen 6 whipple
But keep the boost and TB the same if possible
Bob Lob Law
Jeff
'22 GT 401A ESS A10
The throttle body on the gen 6 VMP is a round one. It's basically a Whipple gen 6 with a round larger throttle body. They teamed up with Whipple. The only one available is currently the stage 3 kit with the larger round tb. They said that down the road they will release stage 1 and 2 with smaller or factory tb.
DefaultDriver1
Damascus Oregon
William
2021 Mustang GT Premium
Roughly 2 months ago I finished installing the VMP Odin kit. Plus the ice tank. Only other mod is an X pipe. Just had it dyno tested to verify the output. Running the 91 octane tune from VMP, the pulley they ship with the kit which is a 3.5 in. and 92 octane super with no additives it made 712 HP and 551 Tq. I believe it 11-12 psi with the base pulley. I am not so sure the whipple is making "more" power. It doesn't seem apples to apples.
J17GT
IL
2017 Mustang GT PP
I’d like to see this too. If you look at Whipple’s website, it’s been updated and shows the gen6 now for 2015+ cars. It still lists the 132mm oval throttle body and not the 112mm round throttle body that VMP is using on the gen6. I wonder if there is really an advantage of one over the other?
HKusp
Hampton, Md.
Jason
Based on my mass air consumption on data logging, I was at around 780whp on the stock engine, Gen5 3.0 Whipple stage2 on 93 octane. My tune is a little spicier than most, as @engineermike can attest.
robvas
MI
2011 GT
What formula are you using and what data point? lb air/min?
HKusp
Hampton, Md.
Jason
Yes, lb/air per minute. It's not a direct correlation, but it's a pretty decent guestimate of 10hp per lb/air per minute. I have seen some very close correlations using that formula. It all comes down to trap speed anyway. Dyno's are so subjective. Operator input, which brand, SAE corrected/not, etc.
Bob Lob Law
Jeff
'22 GT 401A ESS A10
According to the video that VMP put out the round tb is supposed to be easier to tune.
Autopart101
Joe
2020 GT
Looks about right for 13psi boost and 20* timing.
DevonTK
Vacaville
Devon
2019 mustang gt gen 5x whipple
Whats the difference between my gen 5 whipple stage 2 with the gen 6 rotor pack and the gen 6 stage 2?
HKusp
Hampton, Md.
Jason
That's the $64,000 question. It has been postulated that not much is different at all.
J17GT
IL
2017 Mustang GT PP
I know they said that, but I’m not sure if I believe it. Iā€˜m not aware of any tuning issues on the 132mm that Whipple has been using for years.
The gen6 kits on the 2024 mustang also use the same 112mm throttle body that VMP is using. I wonder if it’s a misprint on whipple’s website?
