Fuel System - Harness/Wiring
JGalarse14
Oklahoma
Jason
2021 Mustang Mach 1 Premium
Hey all,
just wanted to see what y'all have done to hide this or any thoughts/opinions on the best ways to do so. It’s just such an eye sore lol, I know it’s “hidden” in the trunk, but still.
NGOT8R
Adrian
2019 Bullitt
Is there room in your spare tire well to mount it in there?
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Mine is down in the spare tire well.
SheepDog
Colorado
Dax
Hey all,
I ran mine like this. Take the liners out of the trunk, and run the wires behind them. I'll get a picture when I get home for you. This way you can still use your trunk space, and install a spare tire (which you can't if you put the controller in the spare well)
I then used these super strong magnet wire clips to hold everything. They swivel and keep everything well organized and safe
MagDaddy - 1/2" Magnetic Cable Clamp - 26lb Rating - B - WireCare.com
JGalarse14
JGalarse14
Oklahoma
Jason
Thank you very much for taking the time to write this! I will follow the way yours is set.
SheepDog
Colorado
Dax
I did mine like this. (Obviously I have a different controller, but same idea) Now I just need to figure out a cover, probably something wrapped in carpet that has hinges, so it swings down for easy access, but protects the controller and wiring from getting bumped. I never really have anything in the trunk, but as you can see this controller has exposed power and ground terminals
5.0_Lojos
Miami FL
Carlos
2016 Mustang GT Premium
Kinda off topic but along the lines of the fuel system. When I had Fore set me up the recommended fuel system for my applications I just recently noticed they had me on 274 pumps oppose to the 285. Kit was just ordered so I'm having it switched out. Is everyone running the 285 fuel pumps? The $$ is not much more.
SheepDog
Colorado
Dax
You can see some of the comparisons here. The 285 draws quite a bit more current than the 274, for not much more flow. It's going to create a lot more heat in the fuel. If you aren't trying to make 1200+ wheel with two pumps, go with the 274's.
Ti Automotive (Walbro) 274 vs 285 vs 295 | SpoolStreet Forums
5.0_Lojos
Miami FL
Carlos
HKusp
Hampton, Md.
Jason
I'm running twin 274's for 15K miles, with plenty of headroom on 93. Radium bucket that came with the Arcane stage 2 set-up. I just ran from the Baltimore area to Lexington, South Carolina and back Friday and Saturday. Not a hiccup.
