Fuel recommendations / octane booster
Big John
Tulsa Oklahoma
2020 GT500 CFTP
Looking for advice...
The metro I live in stopped carrying 93 octane fuel many years ago. The closest station with 93 is an hour + drive. So, I’m left with using 91 as my only local choice.
What if any octane boosters do you recommend? How effective are they? Do they cause any problems down the road?
hossman
2021 Shelby GT500
Boostane all the way. I run a splash of it every tank of 93 and a full bottle when I run my 100 octane tune. 13,600 trouble free miles and counting.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
I also recommend Boostane. That reminds me, I have an unused case I need to list for sale. I used it with my Whippled car I no longer have.
FastCarFanBoy
2013 GB GT
no corn in Oklahoma? If thats not an option than Boostane or Torco work well.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
While we are on the subject of octane, would one of you experienced with converting to E85, please explain what is involved. Are the negative aspects regarding ethanol and rubber/vinyl resolved with the new vehicles or will there still be degradation after the vehicle has been tuned for E85?
V00D00
Dover DE
2020 GT500
Just buy ms109 and mix it. Safer and better than any over the counter octane booster.
You could also look into water/methanol injection. It will cool everything as well as adding effective octane. Quality parts go a long way, and 2.5g tank should last a while, you can easily put distilled water, or straight windshield washer fluid in (70/30)
E85 requires 33% more fuel to produce the same power, but has a much higher octane rating, as well as cools inside the combustion chamber allowing for more boost/timing for greater gains.
Older cars suffer from fuel systems that will be eaten by the ethanol (lines/fittings), newer cars are compatible
Snoopy49
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
Don't forget engine oil contamination, requiring more frequent oil changes.
Big John
Big John
Tulsa Oklahoma
2020 GT500 CFTP
V: Thanks for the great advice. What mix ratio do you recommend? (5 gallons and top off with 91?) Also, what’s the shelf life? Is it better to buy it in 5 gallon or 30 gallon quantities?
kilobravo
Corpus Christi, TX
kilobravo.com
KB
V: My own thanks for that valuable tip and of course, as a "waxer," <chuckling> I didn't know what MS109 was. Now I do.
93 is still readily available in South Texas so I too am interested in your recommendation on ratios. In my case, simple, hard, street driving using 93.
For less than twenty bones per gallon, if the ratio is decent, that wouldn't be THAT much more in fuel costs. But, like Big John, I wonder about the life longevity when buying five gallons.
Thanks in advance...
FastCarFanBoy
2013 GB GT
Ive been running E85 for about a year with no issues, I daily my car so no water intrusion problems and I change my oil every 4k.
You'll either have to wait to see whether the stock fuel system can support E85 as far as volume or be the guinea pig yourself. I'm betting nothing more than a BAP will be needed at most.
I'm running a 13/14 GT500 fuel hat in a return setup and it handling 750whp on E85 with no BAP, im betting the G6 GT500 will have an better fuel system than the G5
FastCarFanBoy
2013 GB GT
V and Earl: Thanks for the insight but I'm curious about E85 requiring 33 percent more fuel. Is the trade off more horsepower?
It requires more fuel because each molecule produces 30% less energy when burned. the trade off is that E85 is at least 105 octane but it t's detonation resistance seems much higher than 105 octane gasoline so it allows more timing advance for more power. I see 22deg advance on E85 vs 17deg on pump 93. It also provides a greater cooling effect when it vaporizes vs gasoline.
Bonus is E85 wont make you stink if you run no cats.
Snoopy49
Earl
