Front splitter scuffs
Joker721
Henderson, NV
Jim
01 Bullitt DHG, 2020 Camry WCP TRD
What do you guys do for front splitter scuffs? Haven’t had any yet but curious what works best other than not to get any.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
I have scraped a ton by now (8K miles) and its very minimal wear on the bottom. You have to look directly under to see it. I have learned to scrape less, but even in steeper driveways I like how much flex the splitter gives you, it bends nicely.
Oakley
Lee
2022 Mustang
don't worry about it if its on the bottom. everything from civics to paganis get em.
If you're referring to the edging of the splitter, you can get a sand block and with emery paper; lightly sand the edge on an angle horizontally and it will remove any burrs.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
+1, yep it scrapes off pretty easy on the edges
Joker721
Joker721
Henderson, NV
Jim
I will check that out! Thanks. Scuffs are going to happen
TicTocTach
DFWTX
Clair
2018 EBPP
Hurricane
Coastal NC
Ted
Mach 1, '21 330i (Wifemobile)
@Joker721 if you ever severely damage/break it beyond repair, you can get a matte black knock-off replacement here for $150: https://www.amazon.com/dp/B0BBKRCX3Q/?coliid=I15QBJPWY7ZZ3B
That's what I'm going to buy if I ever decide to add the Handling Package lip to my M1. Not sure if that'll ever happen though. Lots of speed bumps and irregular terrain/driveways around here that would eat that splitter for lunch. Pretty much the same reason my car will remain at stock height and never get lowering springs.
EDIT: Sorry, I just noticed you don't have the handling package splitter. Oh well, hold onto the link anyway in case you want to add it down the road!
Ewheels
SoCal
Eric
'18 GT PP1, '23 F150, '24 4Runner Pro
Splitters are a consumable. The lowest part of your car is going to take some damage and need replacing over time. This is why most DIY club racers make theirs out of plywood because they get destroyed so frequently and they're easy to replicate.
Joker721
Joker721
Henderson, NV
Jim
The shopping cart was stuck in the tree island so it wasn’t going anywhere. The shopping cart proximity sensors did their job😎
TRDFurgesson
Mid Ohio
www.youtube.com
Bobby
22 Mach1 N0426, 22 Bronco Wildtrak 2dr, 92 Yota 4x
I don’t think you can scrape it enough to hurt it. I’m pretty careful I still scrape it. Usually it’s the pan underneath that you’re scraping and not the splitter but worst case you can always get another one. You learn pretty quickly to take those big dips at an angle. I had to pull mine off to install the long tube headers and reinstalled it pretty easily with plastic rivets from harbor freight.
