Scuffs on door panels
Joker721
Henderson, NV
Jim
01 Bullitt DHG, 2020 Camry WCP TRD
What do you guys use to remove stubborn scuffs on the inside door panels ?
Jim
AZ_Ryan
Arizona
2015 GT Premium
Usually a wet towel does the trick. If not just use warm water and soap. Don't use interior detail sprays until the plastic is clean and dry.
Scat2018
New Jersey
Anthony
18 Dodge Charger scat pack
I heard of using magic erasers, but have not tried it
Nixtide
Oklahoma
2022 Eruption Green M1 HP 6sp Tremec
Watching thread, been wondering about this myself.
-Nix
Joker721
Joker721
Henderson, NV
Jim
Wondering if the magic eraser would remove it but make the color of the plastic lighter?
MACHtobers Very Own
Hampton Roads, Virginia
2022 Mustang MACH 1
I would stick with soap/water or an APC.
determine if the black "coloring/paint/etc" is damaged.
it it's damaged welp that sucks
If not apply a dressing and repeat a few times the cleaning.
AZ_Ryan
Arizona
2015 GT Premium
Bro, you just need to clean the plastic thoroughly with hot water, soap, and a brush. P&S makes a good cleaner, that you can spray on and let sit if needed.
keep in mind the plastic does not stain, but dirt and oils stick to it very easily and can be stubborn because of the texture.
Joker721
Joker721
Henderson, NV
Jim
Got it. I will try that
Thanks Ryan
Rael
Grateful Member
South California
2022 Mach 1 HP Tremec
Just make passengers take off their shoes first.
Rev68
South Dakota
2021 Mach 1
I typically just use a slightly damp cloth, but occasionally (like today), I'll put the tiniest amount of P&S Absolute on the cloth.
Joker721
Joker721
Henderson, NV
Jim
It’s on the driver side originally when I bought the car used
