1st: 5000kWhen are you guys doing your first oil change?
Reading some posts and blogs I've seen 3 opinions on this.
1. Some manufacturers recommend going the whole oil cycle because they include an additive that helps to collect the tiny metal break-in metal bits.
2. Go 1000 miles break-in and change the oil
3. Change it asap to what you feel is better.
When are you planning to change your oil?
Just changed the oil for the first time after 3.5 months of ownership and 1500 miles. 5w-20 Motorcraft full synthetic and a Ford Racing oil filter.
Some observations, comments and questions...
First, the Ford Racing oil filter was much larger in girth and length (giggidy :lolthan the factory one. Will I need to add add'l oil to make up for this added capacity? I filled it back up with 8 quarts.
Second, did anyone remove the two wires going into that control module on the steering rack so you didn't get oil on them from the filter? I opted not to this time as I just covered them with a rag, but might next time.
What was everyone's oil life reading when you reset? Mine said 74%, and again I had 1500 on the car in 3.5 months.
Finally, this will likely be the first car I've had where 3 months will come far quicker than 3k - 5k miles. Is that time interval still recommended for an oil change, or can she go 6-9 months on the same oil if I haven't reached my mileage threshold?
I did... does that seem low? Seems somewhat normal to me just doing the simple math of 25% reduction every 1500 miles, or approximately 0% at 6,000 miles (given conditions, driving habits, etc. remain constant). Yours seems a little a bit high. 25% reduction every 3,500 miles, or 0% at 14,000, again, conditions, habits, etc. remaining constant. :shrug:Seriously !? - you had a oil life of 74% with 1,500 miles after 3.5 months !?
Gee - I have 75% oil life with 3,500 miles after 3 months.
(I changed the oil at 3,500 miles)
Nothing wrong with that, I dont think its detrimental to the engine at all. :shrug:You guys make me feel bad for going a full 5,000 miles before changing her oil...
My dealer said, "See you in 5000 miles!" So who am I to question? I think I am going to get the Amsoil MTF and have them swap out the fluid though.Nothing wrong with that, I dont think its detrimental to the engine at all. :shrug:
