First GT500 oil change
Houston Kid
Houston, TX
In most electronic fuel injected engines, when you hold the gas pedal to the floor and then turn the key (push the button) the engine turns over without spark or fuel. So it is the perfect way to prime the oil system if you don't have a dedicated electric oil pump for priming.
I never knew this. That is an awesome bit of knowledge.
Rapid Red
Woodstock GA
Greg
I fill the filter full let it sit, the element absorbs the oil. This allows it to be installed with out spilling.
Then crank, having the filter element pre saturated, shortens the time of the charge.
Always another way to skin a cat.
Snoopy49
California
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
This what what I have always done. My F250 PS had a filter that held 2 quarts, so I always pre-filled it.
Tomster
Tomster
Beware of idiots
Tom
so I topped the oil off today.... well at least I tried.... the car took all 12 quarts and it still wants more. It looks like it is about .5 of a quart shy of full. The GT500 specs say capacity is 11.5 qts.
Any similar observations?
Shelby2
New York
Craig
2015 F150 Whipple 2.9L, 2018 GT350, 2020 GT500 L0240
12.0 qts. gave me this.
Rapid Red
Woodstock GA
Greg
By chance you use a dry filter, if yes? Most likely the dip stick is showing what has been absorbed by the filter element. They will suck up more oil then you may think.
Use WIXs myself it holds close to 3/4 of a quart, when saturated.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
It would seem this is the case with many Fords based on the forums. My new F150 calls for 9 quarts, but takes 9.5 to hit the top fill mark on the stick.
marklboris
Sonora, CA
Mark
______ '20 Shelby GT500 FPB '24 Mach-E GTP GGM
Cgouzoulis
chris
None
Mine took 12 as well
Rapid Red
Woodstock GA
Greg
No need to buy a case for 1 qt.
Tomster
Tomster
Beware of idiots
Tom
Ive got a bunch laying around for the GT350Rs. That car only takes an even 10 qts.
