Failing inspection - SOS
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
No check engine light, monitors not ready are cats, O2S, HRT
Hoping it’s not the headers.. that’d be a pain
It's the headers, just because it has cats doesn't mean they will let the car get to readiness. What state?
Dave2013M3
El Segundo,Ca
New York, any advice?
To be frank I think you are going to have to bite the bullet and get a set of OEM headers/cats. Also, even if you get the readiness to go green what if they do a visual and see the headers under there. In Cali thats a fail, being that Cali and New York are very liberal I can't imagine that the smog rules are more lax than in Cali.
I would jump on these...
2015-2017 Headers and cats
jbfj
jbfj
New York
Jack
2017 GT Premium/PP 6spd
Luckily the visual side shouldn’t be an issue, just a matter of passing the readiness. Is it possible I just need the cats cleaned?
CJJon
Port Orchard
2020 Mustang GT/CS Convertible - Race Red
Cats cleaned? Is that a thing?
Dave2013M3
El Segundo,Ca
I would try some defoulers first, cleaning of the cats is probably not the issue. Its probably the location of them are keeping the signal not in spec. Also most of the cats that come with LTHs are crap, I am generalizing. I would give these a try, you did install the OEM software right?
defoulers
Chef jpd
Brooklyn, NY
O2 sensor spacers will cure 2 of those readiness prob!ems.
Chef jpd
Brooklyn, NY
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
If it’s been that long without the cat monitors going ready, and the CEL hasn’t appeared, it’s the tune. They probably shut off the LTFT’s, or injector disable at coast. No 02 spacers are going to save you in this scenario. Data log the car for a few minutes and see if the LTFT’s are active. Also when letting off after accelerating over 50mph, does your AFR go to 20:1?
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
All of this ^^^^
Whitewalkers550
Fort worth
2017 mustang gt premium, 1973 mustang conv.
i just went through this, tune should take care of it and depending on your driving it could take a bit to reset i think mine finally all got in the green at like 175 ish after i had a new tune put on it
Dave2013M3
El Segundo,Ca
I thought OP installed the OEM software? If he has, the reason he hasn't got a CEL could be due to the cycles, also when even you go WOT it can delay the CEL. If he doesn't have the OEM software installed than CoryS nailed it.
jbfj
jbfj
New York
Jack
Rgr. Also, given the mods, trying to put it through a drive cycle is likely a bad idea right?
didn’t have OEM software installed when it was failing Cats, O2S, and HRT. Set the tune back to stock just to see if that changed anything and then it failed a bunch more too (pic above).
Cory S
Bradford, NH
Cory
Will it start run and drive on the stock calibration?
