Enclosed Trailer & Towing Help
16Kobra
2019 GT350R
Im concerned about MPG. not because i care, but south florida to delaware, i had to stop every 2 hrs for fuel.. that was a PITA getting home. I may have to custom order a truck now as well. final piece to the puzzle, GT500+ Explorer ST, and now Raptor/Limited or F250..
Not sure there is a truck out there that can go much more than 2 hrs for fuel pulling the trailer.
My excursion is 44 gal, 7.3L diesel and I am at 2.5 to 3 hrs for fuel.
Jmeo
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Does your truck have the 36 gallon tank? I need to pee WAY before the truck needs gas lol.
Big John
Tulsa Oklahoma
2020 GT500 CFTP
ZX3ST
STL
2018 GT350, Kona Blue, J3116
I'll let OP comment on his fuel usage, but thought I'd offer a data point.
F150 with the max tow package gets the 3.5 ecoboost and 36gal (vs 26gal standard) fuel tank. I see around 12.5-13.5mpg with my open trailer using cruise and running the speed limit. I suspect I could get an extra 0.5-1 mpg if I didn't use cruise.
So with that combo 400mi on a tank of gas for me is no problem. I usually like to stop every 200mi anyways just to take a break, regardless of whether I need fuel.
I didn't need to order mine. There were plenty out there on dealer lots.
Jmeo
Jmeo
You said member ;)
Massachusetts
Jaime
Thanks for the info. I will be taking my first trip with it the first week of August when I go to Ford Nationals in Carlisle, PA. I haven’t seen what I will get for mileage yet, and I was kinda wondering in what ball park it will be. The Limited has the same H.O. EcoBoost that’s in the Raptor, so I would imagine mileage will be less than the traditional 3.5 EcoBoost. I could be wrong, and the increased HP and better torque will net better results, only time will tell. Either way, I’m getting old, and drink a lot of coffee, which means I’ll be stopping frequently anyway.
ZX3ST
STL
Yes between the slightly higher output engine and larger/heavier trailer I'd agree you can probably expect slightly lower numbers. I would think 11.5-12.0 is attainable just based on my gut intuition but as always YMMV.
Personally, the fact one can get over 10mpg with this kind of towing power and stability (in a 1/2 ton truck, no less) is nothing short of amazing. I was worried F150 wouldn't be "enough truck" but it impresses me every time I use it. And I'm not even using a weight distributing hitch on my rig.
I'd love to hear your experience after your trip.
Jmeo
Jmeo
You said member ;)
Massachusetts
Jaime
I could live with those numbers. I will be sure to report here how it goes.
V00D00
Dover DE
2020 GT500
Just upgrade the size of the fuel tank. I have one of these on my truck. Doubled the capacity.
http://titanfueltanks.com/2018-19-f...neration-6-titan-fuel-tank-48-gallons-7021218
What is the drop F and R of the CFTP springs vs base?
no, mine is the 2.7eco ,, thats where a lot of the issue comes. at the time, i had a 3500lb trailer and a 2500lb race car.. now its 4500lb trailer and 4200lb race car. Plus i drive faster than you guys probably do, i like to cruise at 70, i was getting 9mpg. I would just upgrade the tank, but its still a tiny motor, as well as a want a supercrew cab. so newer truck, bigger tank, super crew, 3.5..
Jmeo
Jmeo
You said member ;)
Massachusetts
Jaime
I rip right along at 70 as well. I hear you loud and clear, you are speaking my language. I couldn't live without the crew cab, and 3.5 EcoBoost is a must towing long distances, and so is the 36 gallon tank. My trailer only weighs 3,250, but when you add the 4,300 (ish) car and all the other goodies loaded in, you are getting up there.
16Kobra
2019 GT350R
I usually tow at 70 with MH or Excursion.
I have a friend in S. Fl, towing his GT500 with a relatively new F350 SRW Diesel. We were talking about "convoying" up to Atlanta this weekend until he told me he tows at 80. Guess I will be behind him.
Goose17
DFW
Tim
Many Mustangs (collector)
I just filmed this video on Sunday... it shows my trailer setup quite well. I pull with a 2010 5.4 F150 super crew cab. I have a 20’ V-nose, dove tail steel enclosed trailer with a driver’s side exit door. I specifically looked for a 20’ V-nose since I am pulling with an F150. A flat front trailer adds a lot of drag. I drove about 1+15 each way and averaged 9 mpg. Keep in mind that as you add length to the trailer, not only do you add weight, but you add surface for crosswinds to grab. A 20’ trailer works great to haul Mustangs around. I hauled my 1st 2020 home from the dealer in this trailer and will haul the 2nd one home as well.
honeybadger
Just don't care
COTA
Kevin
Sounds like an ego-driven statement regarding speed. I've towed over 20k miles on my '17 Raptor with an 8k lbs enclosed trailer. I've towed it on flat surfaces at 55 in the middle of nowhere and at 80 through mountain passes in CA. Ranges 8.4-12mpg depending on the conditions and speed.
FWIW, my dad has a 2017 Super Duty and we've towed the same trailer and car. Gas mileage sucks just about as bad and it doesn't tow any faster any better (in regards to power). They both downshift at the same points, etc. Mileage averaged 0.5-1 MPG better, but the raptor has the bigger tank. The super duty improvements are in stability from the bigger wheelbase and stiffer springs.
Jmeo
Jmeo
You said member ;)
Massachusetts
Jaime
I specifically looked for a 20’ V-nose since I am pulling with an F150. A flat front trailer adds a lot of drag. I drove about 1+15 each way and averaged 9 mpg. Keep in mind that as you add length to the trailer, not only do you add weight, but you add surface for crosswinds to grab. A 20’ trailer works great to haul Mustangs around.]
I had originally ordered mine as a 20' V nose, but decided to add 2' and make it 22' plus V nose. Mine also has the sloping roof line to help with drag.
I look forward to seeing your new CFTP :like:
Goose17
DFW
Tim
22’ sounds like a nice length trailer. I see people often going for a 24’, which is fine behind an F250/2500, but that’s bigger than I prefer for my tow package F150. The sloped front or V nose definitely helps!
Regarding the CFTP... thanks! I too look forward to seeing it. It has a build date of July 8th and I’m expecting it mid August. It’s going to be a long couple of months sans 2020!
