Edelbrock E-Force Troubleshooting Manual
SonicBlur
Schaumburg, IL
2016 Mustang GT Premium
I just use a JLT Whipple compatible one with the hose end cut off to go on the eforce nipple. There are other better/more expensive ones out there...just depends on what you want to spend.
Any chance you have any links to other ones? I'd like to see what is needed....maybe building a kit is a good option.
carguy231
SoCal
2017 Mustang GT
Hey guys, is there an oil catch can setup that is recommended and/or compatible with an Edelbrock blower? I don't have one and I should probably have one, lol
UPR makes one for the Edelbrock. You might have to work on the direction of the hose connections and use a piece of threaded rod and spacers, at least on the driver's side to avoid denting the hood insulator pad.
bhvnce
San Jose California
Chance
2015 Mustang GT
Hey guys I don’t really know if this is the right place for this so I apologize if it doesn’t belong here. Anyways there has been this clicking from the front of the motor ever since I did the install that sounds like it could possibly be a pulley misaligned or something like that. (Video link below) I have also had a problem with a rough idle before the install which was fixed by new VCT solenoids. Then a misfire with plugs that weren’t gapped correctly post install. Now my idle is smooth but there still seems to be some weird noise coming from the exhaust and I can’t quite make out what it is. (Video below) Finally there is a clicking noise that comes from the driver side of the motor that I can only describe after numerous google searches as “lifters clicking” will also post of a video but it’s difficult to hear. All of these have me worried that my timing could possibly be off which is not a cheap fix. I did OPG’s and Crank Sprocket on install but I took extra care to make sure timing was redone correctly… I really hope I didn’t screw that up.
links:
Clicking from pulleys https://youtube.com/shorts/rO5cNPd4W_c?feature=share
Exhaust soundhttps://youtube.com/shorts/XQ9GtCg2y0s?feature=share
Clicking lifters or sticky valves
https://youtube.com/shorts/EqUjFiDzL_o?feature=share
bhvnce
San Jose California
Chance
2015 Mustang GT
links:
Exhaust sound
Stang 19
Ca
2020 GT500 Ford Performance Blue
bhvnce
San Jose California
Chance
2015 Mustang GT
AS for the suspected misfire: if you do not have misfire codes, then probably not an issue. The clicking noise is interesting it does sound like an electrically operated solenoid turning on and turning off I assume you’ve kept all of your omissions equipment intact ?
I apologize to everyone for the terrible grammar, punctuation, and typos!! I was trying to get the message out quick before a meeting this morning so there were lots of mistakes which made that a bit difficult to read. Anyways, no misfire codes but it didn’t throw any codes when I had the gap issue either… would only flash the CEL occasionally under load. The exhaust sound just doesn’t sound normal to me so I’m hoping someone knows what’s going on with that. All of my symptoms fit with the internet diagnosis of timing being out of wack which scares me because I did it myself and could have easily screwed it up. As for the clicking in the front of the motor, I didn’t think of a solenoid actuating which could easily be the case. All omissions equipment are the stock components and I am on the Edelbrock tune, only thing that was removed was the piece that was on the back of the stock intake manifold which has already been addressed in the forum as not used by the Edelbrock kit.
Thanks!
carguy231
SoCal
2017 Mustang GT
links:
The supercharger itself makes more 'noise' than the engine did originally, at least mine does. I don't think you have anything serious going on.
brianbr
Surprise
Brian
2019 Magnetic GT PP
Anybody log their low side fuel pressure on a gen 3 2650 stage 1? As stock from Edelbrock, fuel pressure is around 70psi at idle and drops to 40 psi wide open even though commanded is 72. I just picked up a DW400 to throw in the tank hoping it fixes the issue.
Jobodizo
Jobodizo
Kentucky
2015 DIB GT
FYI, Edelbrock 2nd day air-ed me a pump. Kit is 2.5 years old with 16k miles. Not sure what warranty on parts is, but they took care of me.
Torinate
Ontario
2016 GT Convertible
Awesome! That’s great. I know it was a PITA getting In touch with them, but they came through in the end.
Let’s hope this ones lasts longer!!
carguy231
SoCal
2017 Mustang GT
Got my baseline dyno finally at GTR. This is out of the box 50-state legal for my Stage 2 setup.
Stang 19
Ca
WHat is your next step? Gonna tune it? For comparison, my 19 with the same kit kit made 642.
carguy231
SoCal
2017 Mustang GT
Of course I'll get it tuned... That's the addiction... LOL Seriously, I'm thinking a smaller pulley, and that is it for now. Being in the Republick of Kalifornia, I want to stay reasonably legal, and able to flash back for smog. They noticed a chunk missing out of the serpentine belt, which I haven't picked up yet.
carguy231
SoCal
2017 Mustang GT
Oh, and it was around 85-degrees yesterday. Cooler temps = more power. I'm going to install the Verus hood vents in my stock hood to dump out some of the heat.
