PRG3k
I said goodbye to my base a few months back. Now I have the performance pack.
Cons:
Hate that there's no boost gauge in the center display. However it only goes up to 20 psi anyway. So after a tune it wouldn't matter.
Wheels/tires. Nice finish, hate the design and they're so goddamn heavy I'll be downsizing to my old 18's once the Pirelli's wear out.
3.55 gears are a wash. They're fun. I liked the 3.35's in my base a bit better. Slightly better highway and you don't need help staying in the power band with this motor so shorter gears aren't super necessary.
Pros: Everything else.
Upgraded radiator may not be a big deal to some but here its 90-100 degrees for close to 6 months out of the year.
Brakes - Good lord, the brakes are SO much better on the PP. Worth it for the damn brakes alone! The base brakes felt adequate but I was a little disappointed in them. This is a heavy car that can get up to 100mph pretty quickly, it could use some bigger brakes. These things are no joke I'm telling you.
Suspension - The base suspension felt like a Cadillac. The thing would practically float over speed bumps and the like. The PP is glued. Highway ramps can be taken faster and the car lays more flat through corners. Bumps don't give you the two seconds of undulating feedback that the base did. Much stiffer ride. You only need springs if you want to lower the car. The standard PP stiffness is very sporty.
I justified not getting it before. Now that I have it, it is totally worth it.
Cons:
