Notes
Moustang
Every time I drain my can I'm impressed by how much oil/blow-by it catches, so definitely a good investment. Will be getting the clean side can as well and see what difference that will make.
Please tell me how an ounce of oil, spread out through (500 miles / 18 mpg) 28 gallons of fuel is going to affect ANYTHING? It certainly will not touch the octane rating.When I read some of the replies in here its no wonder this subsection has ground to a halt and many of the seasoned guys with tunes/mods have migrated to facebook groups instead. Its easy to see how some boneheads blow these cars up.
Do you guys not read and see how much oil ppl are draining from these things? I can take a picture to show the ounce or two that mine has in it right now from 500 miles. Don't care if you buy one or not but some things are not really up for debate anymore and the redundancy is getting innocuous.
Plenty of long range comparisons to be had on the Mazdaspeed3 forums (with pictures). Same gene pool as this motor.
Original poster, for 4-5 years you can survive fine without a catch can. I just wouldn't want to be the owner for the next 5 years. If you are tuned, I would consider one now
Deposits on valves.Please tell me how an ounce of oil, spread out through (500 miles / 18 mpg) 28 gallons of fuel is going to affect ANYTHING? It certainly will not touch the octane rating.
Same. I had a considerable amount in my intake manifold/throttle body and some residue in my turbo inlet. I believe that was the cause of my engine lugging and fouling my plugs a little.Can't say definitively yes or no as every car could be a little different.
I will say that I just installed mine last night at 26k miles and based on what I saw in my intake heads and my valves, wish I had done it sooner. Definitely had a noticeable amount of oil buildup. Another 3 years of this, who knows lol.
Link to proof (a photo of catch can output is not proof)?Direct injection is a completely different animal from port (conventional), and it has been well proven that catch cans make a measurable difference in carbon build up, fuel dilution, etc.
It stands to reason that if you see a can full of oil that otherwise would have made its way into your intake, can you not infer from that data that its doing what people claim the oil does when it gets into the intake?Link to proof (a photo of catch can output is not proof)?
Scientifically speaking, no, you can't make that inference because you have changed the system by introducing new airflow paths. I have yet to see anything that constitutes actual proof of anything beyond collecting gunk.It stands to reason that if you see a can full of oil that otherwise would have made its way into your intake, can you not infer from that data that its doing what people claim the oil does when it gets into the intake?
Well yes and no, you only extended existing path inline, in just a two port system anyway, and you do not change the direction of the flow at all. It is not flowing backwards and the facts are that that much oil going in the direction has to pass through the intake from there its obvious where the oil goes. I think you are putting too much thought into a fairly simple setup, and there is enough data online, with manufacturers and the race industry that shows they are effective in most uses providing they are implemented as intended.Scientifically speaking, no, you can't make that inference because you have changed the system by introducing new airflow paths. I have yet to see anything that constitutes actual proof of anything beyond collecting gunk.
I'm not saying catch cans are good or bad; I'm just saying I want to see some actual proof.
That's the best evidence I've seen to date.Here's a thread from the Focus ST forum comparing buildup on 2 cars, one with and one without a catch can.
http://www.focusst.org/forum/focus-...l-catch-can-vs-no-oil-catch-can-pictures.html
One of the cars in the comparison had just over 11,000 miles and the other had 15,000. I would imagine the difference in buildup would be magnified over a longer period of time/more mileage. I'm not sure anyone is going to find better "proof" than that right now.
Most engines have some sort of oil seperator that limits the amount of oil that passes through the PCV valve . The Ecoboost has one of the more elaborate oil seperators on the side of the block where the PCV valve plugs in. These are not as effective as a well designed catch can but they are much much better than no baffling at all.Apparently the new camaro has some type of catch can that drains back to the oil pan on the LS V8. Also, someone on their forum said something about audi/vw having some kind of factory catch can setup on some models.
