E85 no tune
moffetts
San Mateo CA
Black Whippled 2015 GT PP
Correct, as long as you have the stock manifold only. Any other manifold (Boss, 18, CJ, etc.) And you will need to upgrade to LU47 injectors minimum.
Right, but if OP had any of those, he would need a tune anyway.
Deleted member
Guest
15-17 stock injectors are fully capable of running E85 and tuners will gladly tune for them.
Even tuned you will burn up your injectors trying to keep them at the flow rate necessary to run properly, which is why any other intake that flows more than stock manifold needs more juice.
moffetts
San Mateo CA
I’ve never heard of that. Anecdotally, my car ran great with nothing but a Lund FF tune, and my E85 was spicy stuff.
Nuked
Morgantown, WV
2016 Triple Yellow GTPP w/Recaros
What do the fuel trims look like? Specifically short term at WOT?
K4fxd
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Bank one .98 Bank two .99
They hold steady from 3000 to 6000 where I let off.
Measured AF is .85 both banks
brucelinc
MN
Bruce
2018 Mustang GT premium A10 (SOLD)
Not sure about the OP's area but in many places E85 is still only around E54 this time of year. That could explain why his data looks reasonable.
Nuked
Morgantown, WV
It is still not reasonable. The car is configured for E10 stock. So with fuel trims within 1% of achieving the commanded AFR, it doesn't add up.
OP - are you sure you don't have a Flex tune loaded? Does the datalog/ngauge (assuming this is what u have since you said calling Lund) show Ethanol % or FF learn?
K4fxd
K4fxd
NKY
I topped off with E85, it took 7 gallons to fill the tank. This was an experiment to see if the car would correct for the added alcohol. I have no idea what the actual percentage the E85 is.
Butt dyno says the car is MUCH more responsive to drive. I will get a Flex tune
I have been looking at HP and it looks relatively easy to do
K4fxd
K4fxd
NKY
No tune. I did drive for 100 miles before I got on it.
NotMarc
Earth
22 Mach 1
Maybe this is a stupid question, but may I ask why?
K4fxd
K4fxd
NKY
Because I'm a hot rodder.
My F150 is flex fuel with the same engine, I want to find out if the mustang is also.
Looking at some flex tunes from HP it looks like it does need a switch turned on and some tables modified.
Jmtoast
Michigan
2018 Roush GT
You're a pioneer... Send it.
K4fxd
K4fxd
NKY
I want the torque of the truck and the HP of the mustang. Someone needs to design a variable length intake manifold.
Nuked
Morgantown, WV
put a TVS on it, problem solved.
