E85 no tune
zworld
wichita ks
zane
2018 mustang gt
Lambda is lambda regardless of what fuel. If you're targeting to a lambda reading, changing fuel to something like E30 will require more fuel to reach the same lambda. . So you should see an increase in injector duty cycle. Ford trims the fuel 0-15% (E0-E15). Therefore, running E30 it'll be running lean at WOT.
So wild horse you seem pretty knowledgeable so your saying I should just go back to the regular 91 octane? I'm still on that first tank and still had a 1/4 tank of 91. You think I'm ok?
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
You think I'm ok?
You have 16 injectors. You're more than OK. But yeah, I'd go back to 91. If you wanna experiment with ethanol, get a flex tune from LUND. You can't go wrong there buddy :)
K4fxd
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I put 7 gallons to a full tank of what probably is E50 and my data logs look perfect.
I suppose I could post one. I would not be scared of 1.5 gallons of true e85 in MY car. It is adding timing, it is adding 5 plus everywhere, it is holding lambda and it is running .85 at WOT. It is running so much better that I ordered a flex tune.
I have a Lund tune in my truck, it is a good runner. I will no longer deal with his company simply because I like to use the phone. I got that tune when his company number was public.
EDIT to clarify.
It was 7 gallons of pump E85 to a full tank of 93 Costco E10
K4fxd
K4fxd
NKY
That is what the logs say .85 that is. The car shows 12. something on the dash display. It is calibrated for E10 because it also shows 14.0 at idle.
No issues, it runs like a top.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
What the logs show for timing? max? knock? etc. Thanks.
dn1984
SF Bay Area
2018 Mustang GT A10 Premium
my car on E30 stock tune dips to the mid-low 11s range AFR at WOT and i saw it dip below 11 once too
FruityJudy
South Alabama
2018 Mustang GT A10
I’d like to see you go to zero miles to empty and fill with E85 at least before you tune it
Laztug
Wanna run dyno slips bro?
COTUS
Calling out OKC #1 spot after axle back install.
I completely understand why Lund quit taking phone calls.
Zelek
Hutto, TX
2021 Mustang Mach 1
Because of people like this and the fact that there's no need to talk on the phone.
FruityJudy
South Alabama
2018 Mustang GT A10
Lund can probably answer 30 emails faster than he could sit and discuss with 1 customer on the phone. Plus with email there is a paper trail on all convos. No need in having a phone ringing off the hook
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Add to that what does the short term AFR say? Nevermind what the BS on the dash tells ya.
K4fxd
K4fxd
NKY
I already posted the STFT's
I wanted to see what the stock computer is capable of. I did an experiment and gave my results. I am being bashed for even trying it, and now I'm being told I'm a fool for wanting to talk with a business before I give them my money. Had I found Lunds number and talked with him he would have gotten my order for a flex tune. It's my choice who I do business with and same for ones I will not.
I'm out of this thread.
